yum-config-manager --enable rhui-REGION-rhel-server-optional
yum repolist all
yum clean allHow do I install Nagios? I am running ./fullinstall
It is giving me an error. Here is the tail of the output:
Total download size: 49 k
Installed size: 23 k
Downloading packages:
Running transaction check
Running transaction test
Transaction test succeeded
Running transaction
Installing : iptables-services-1.4.21-13.el7.x86_64 1/1
warning: /etc/sysconfig/iptables created as /etc/sysconfig/iptables.rpmnew
Verifying : iptables-services-1.4.21-13.el7.x86_64 1/1
Installed:
iptables-services.x86_64 0:1.4.21-13.el7
Complete!
Failed to issue method call: Access denied
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './6-firewall'
Here is where the word error appears in install.log
# cat install.log | grep -i error
ERROR: unable to read system id.
http://mirror.oss.ou.edu/epel/7/x86_64/repodata/dd5cf6a19fbbe585a0dcb7b4dd9e2861d4017cfc5439cf6fc8bef73f646ff19b-primary.sqlite.bz2: [Errno 14] HTTP Error 404 - Not Found
--> Processing Dependency: perl(Error) for package: nagiosxi-deps-el7-2014r2.6-1.noarch
---> Package perl-Error.noarch 1:0.17020-2.el7 will be installed
Error: Package: rrdtool-1.4.9-1.el7.x86_64 (nagiosxi-deps)
Error: Package: perl-Net-SNMP-6.0.1-7.el7.noarch (epel)
Error: Package: nagiosxi-deps-el7-2014r2.6-1.noarch (/nagiosxi-deps-el7-2014r2.6-1.noarch)
Error: Package: perl-Mail-IMAPClient-3.34-1.el7.noarch (epel)
perl-Error noarch 1:0.17020-2.el7
Installing : 1:perl-Error-0.17020-2.el7.noarch 133/281
Verifying : 1:perl-Error-0.17020-2.el7.noarch 246/281
I did this in /etc/
chmod 777 sudoers
I re-ran the install script. But the error was the same. I don't know what access is denied. I am running the install script as root. I reverted the sudoers file to having 440 permissions.
