Log Server Mointoring
Re: Log Server Mointoring
Now this is for the server of the client?
I am talking about the client machine where the logs reside that you'd like to parse. The plugin (check_log3) will need to run on the client machine to return proper results.
The client should have the sudo settings specified as well, and the nagios user should be able to 'sudo' run that command with no problems.
We will need an agent to transport this data - presumably NRPE. Are you using NRPE? If so, please post the client machines configuration.
we are using 6.6 red hat on a vm
2.6.32-504.16.2.el6.x86_64 #1 SMP Tue Mar 10 17:01:00 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
and use xinetd
When i do
I get OK: Found 0 lines (limit=1/1): No matches found.|lines=0
But nagios gives me this error
(No output on stdout) stderr: sudo: no tty present and no askpass program specified
and use xinetd
When i do
su - nagios
/usr/local/nagios/libexec/check_log3.pl -l /var/log/messages -p someline -c 1
This is for client
# Sample NRPE Config File
# Written by: Ethan Galstad ([email protected])
# Last Modified: 11-23-2007
# NOTES:
# This is a sample configuration file for the NRPE daemon. It needs to be
# located on the remote host that is running the NRPE daemon, not the host
# from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number. The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/var/run/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
# NRPE USER
# This determines the effective user that the NRPE daemon should run as.
nrpe_user=nagios
# NRPE GROUP
# This determines the effective group that the NRPE daemon should run as.
nrpe_group=nagios
# ALLOWED HOST ADDRESSES
# This is an optional comma-delimited list of IP address or hostnames
# that are allowed to talk to the NRPE daemon.
# Note: The daemon only does rudimentary checking of the client's IP
# address. I would highly recommend adding entries in your /etc/hosts.allow
# file to allow only the specified host to connect to the port
# you are running this daemon on.
allowed_hosts=127.0.0.1, 10.1.1.151, 10.1.1.9
# COMMAND ARGUMENT PROCESSING
# This option determines whether or not the NRPE daemon will allow clients
# to specify arguments to commands that are executed. This option only works
# if the daemon was configured with the --enable-command-args configure script
# option.
# *** ENABLING THIS OPTION IS A SECURITY RISK! ***
# Read the SECURITY file for information on some of the security implications
# of enabling this variable.
# Values: 0=do not allow arguments, 1=allow command arguments
dont_blame_nrpe=1
# COMMAND PREFIX
# This option allows you to prefix all commands with a user-defined string.
# A space is automatically added between the specified prefix string and the
# command line from the command definition.
# *** THIS EXAMPLE MAY POSE A POTENTIAL SECURITY RISK, SO USE WITH CAUTION! ***
# Usage scenario:
# Execute restricted commmands using sudo. For this to work, you need to add
# the nagios user to your /etc/sudoers. An example entry for alllowing
# execution of the plugins from might be:
# nagios ALL=(ALL) NOPASSWD: /usr/lib/nagios/plugins/
# This lets the nagios user run all commands in that directory (and only them)
# without asking for a password. If you do this, make sure you don't give
# random users write access to that directory or its contents!
# command_prefix=/usr/bin/sudo
# DEBUGGING OPTION
# This option determines whether or not debugging messages are logged to the
# syslog facility.
# Values: 0=debugging off, 1=debugging on
debug=0
# COMMAND TIMEOUT
# This specifies the maximum number of seconds that the NRPE daemon will
# allow plugins to finish executing before killing them off.
command_timeout=60
# CONNECTION TIMEOUT
# wait for a connection to be established before exiting. This is sometimes
# seen where a network problem stops the SSL being established even though
# all network sessions are connected. This causes the nrpe daemons to
# accumulate, eating system resources. Do not set this too low.
connection_timeout=300
# WEEK RANDOM SEED OPTION
# This directive allows you to use SSL even if your system does not have
# a /dev/random or /dev/urandom (on purpose or because the necessary patches
# were not applied). The random number generator will be seeded from a file
# which is either a file pointed to by the environment valiable $RANDFILE
# or $HOME/.rnd. If neither exists, the pseudo random number generator will
# be initialized and a warning will be issued.
# Values: 0=only seed from /dev/[u]random, 1=also seed from weak randomness
#allow_weak_random_seed=1
# INCLUDE CONFIG FILE
# This directive allows you to include definitions from an external config file.
#include=<somefile.cfg>
# INCLUDE CONFIG DIRECTORY
# This directive allows you to include definitions from config files (with a
# .cfg extension) in one or more directories (with recursion).
#include_dir=<somedirectory>
include_dir=/usr/local/nagios/etc/nrpe
# COMMAND DEFINITIONS
# Command definitions that this daemon will run. Definitions
# are in the following format:
# command[<command_name>]=<command_line>
# When the daemon receives a request to return the results of <command_name>
# it will execute the command specified by the <command_line> argument.
# Unlike Nagios, the command line cannot contain macros - it must be
# typed exactly as it should be executed.
# Note: Any plugins that are used in the command lines must reside
# on the machine that this daemon is running on! The examples below
# assume that you have plugins installed in a /usr/local/nagios/libexec
# directory. Also note that you will have to modify the definitions below
# to match the argument format the plugins expect. Remember, these are
# examples only!
# The following examples use hardcoded command arguments...
#command[check_users]=/usr/local/nagios/libexec/check_users -w 5 -c 10
#command[check_load]=/usr/local/nagios/libexec/check_load -w 15,10,5 -c 30,25,20
#command[check_hda1]=/usr/local/nagios/libexec/check_disk -w 20% -c 10% -p /dev/hda1
#command[check_zombie_procs]=/usr/local/nagios/libexec/check_procs -w 5 -c 10 -s Z
#command[check_total_procs]=/usr/local/nagios/libexec/check_procs -w 150 -c 200
# The following examples allow user-supplied arguments and can
# only be used if the NRPE daemon was compiled with support for
# command arguments *AND* the dont_blame_nrpe directive in this
# config file is set to '1'. This poses a potential security risk, so
# make sure you read the SECURITY file before doing this.
#command[check_users]=/usr/local/nagios/libexec/check_users -w $ARG1$ -c $ARG2$
#command[check_load]=/usr/local/nagios/libexec/check_load -w $ARG1$ -c $ARG2$
#command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
#command[check_procs]=/usr/local/nagios/libexec/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
[root@vm01 etc]#
This is for the nagios server
# NOTES:
# LOG FACILITY
log_facility=daemon
# PID FILE
# PORT NUMBER
server_port=5666
# SERVER ADDRESS
# NRPE USER
nrpe_user=nagios
# NRPE GROUP
nrpe_group=nagios
# that are allowed to talk to the NRPE daemon. Network addresses with a bit mask
# (i.e. 192.168.1.0/24) are also supported. Hostname wildcards are not currently
# supported.
# option.
dont_blame_nrpe=0
# BASH COMMAND SUBTITUTION
# to specify arguments that contain bash command substitutions of the form
# $(...). This option only works if the daemon was configured with both
# the --enable-command-args and --enable-bash-command-substitution configure
# script options.
# *** ENABLING THIS OPTION IS A HIGH SECURITY RISK! ***
# Values: 0=do not allow bash command substitutions,
# 1=allow bash command substitutions
allow_bash_command_substitution=0
# COMMAND PREFIX
# Usage scenario:
# DEBUGGING OPTION
# syslog facility.
debug=0
# COMMAND TIMEOUT
command_timeout=60
#include_dir=<someotherdirectory>
# examples only!
On your client, let's add a command to your NRPE configuration:
After the above command has been added, please save your nrpe.cfg and restart xinetd:
This will associate the command definition of 'check_log_3' with the parameters '/usr/local/nagios/libexec/check_log3.pl -l /var/log/messages -p someline -c 1'. What this means is that all we have to do to run '/usr/local/nagios/libexec/check_log3.pl -l /var/log/messages -p someline -c 1' on your client server is call the associated command definition.
From your XI server, run the following:
Let me know if the above works for you. Thanks!
command[check_log_3]=/usr/local/nagios/libexec/check_log3.pl -l /var/log/messages -p someline -c 1Code: Select all
service xinetd restartFrom your XI server, run the following:
/usr/local/nagios/libexec/check_nrpe -H client.ip.goes.here -c check_log_3Re: Log Server Mointoring
[root@nagios ~]# /usr/local/nagios/libexec/check_nrpe -H client.ip.goes.here -c check_log_3
CHECK_NRPE: Error - Could not complete SSL handshake.
On your client, make sure that you have the only_from variable set properly:
Restart xinetd after making the above change:
From here, try re-running the check from XI and report the results back here.
[root@nls1 ~]# cat /etc/xinetd.d/nrpe
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
flags = REUSE
socket_type = stream
port = 5666
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nrpe
server_args = -c /usr/local/nagios/etc/nrpe.cfg --inetd
log_on_failure += USERID
disable = no
only_from = nagios.xi.server.ip
}Code: Select all
service xinetd restartRe: Log Server Mointoring
it is right
other service are giving me results so this has to be running.
service nrpe
flags = REUSE
port = 5666
wait = no
user = nagios
group = nagios
disable = no
only_from = 10.1.1.151 10.1.1.9
Perhaps you are not using SSL:
Can you get an NRPE return message using either of the below commands?
/usr/local/nagios/libexec/check_nrpe -H client.ip.goes.here -c check_log_3 -nCode: Select all
