NRPE Socket Timeout when running check that loads PSSNapin f
Re: NRPE Socket Timeout when running check that loads PSSNap
Try changing the command in the nsclient.ini to the following to see if this fixes it for you.
check_queue_health=cmd /c echo scripts\QueueHealth.ps1; exit $LastExitCode | PowerShell.exe -Command -
ads1923
Post by ads1923 »
Thank you for the replies. I updated the nsclient.ini file with this: check_queue_health=cmd /c echo scripts\QueueHealth.ps1; exit $LastExitCode | PowerShell.exe -Command -
I ran nscp.exe test
check_queue_health
The local server reported:
d rvice\NSClient++.cpp:616 NSClient++ - 0,4,1,105 2014-04-28 Started!
l ce\simple_client.hpp:32 Enter command to inject or exit to terminate...
check_queue_health
d rvice\NSClient++.cpp:960 Injecting: check_queue_health...
d kExternalScripts.cpp:249 Command line: cmd /c echo scripts\QueueHealth.ps1; exit $LastExitCode | PowerShell.exe -Command -
d rvice\NSClient++.cpp:985 Result check_queue_health: OK
l ce\simple_client.hpp:80 OK:OK: All mail queues within limits.
exit
When I run this: ./check_nrpe -H nwk-mbx13p-w02.pex.exch.apple.com -c check_queue_health -t 30 from the Nagios server I get the same result as before
CHECK_NRPE: Socket timeout after 30 seconds.
ssax
Dreams In Code
Post by ssax »
At the bottom of your nsclient.ini
Remove:
allowed hostes = 10.10.10.10, 10.10.10.20
Change:
allow nasty_meta chars = 1
To:
allow nasty characters = 1
Restart your nsclient service and try it again.
ads1923
Post by ads1923 »
I made the changes to the nsclient.ini file that you suggested and I get the same result.
Post by Box293 »
On your Windows server run these commands:
cd "\Program Files\NSClient++\"
nscp settings --activate-module NSClientServer --add-defaults
nscp settings --path /settings/log --key level --set debug
Restart the NSClient++ Service.
Now go and perform:
ads1923 wrote:When I run this: ./check_nrpe -H nwk-mbx13p-w02.pex.exch.apple.com -c check_queue_health -t 30 from the Nagios server I get the same result as before
After it completes post the results from the nsclient.log file created.
ads1923
Post by ads1923 »
I followed your steps and ran the command from the nagios server. Attached is the nsclient.log that you requested.
I still get the same response on the nagios server. Just a reminder i have 3 other servers in these subnet that are working using the same nsclient.ini file and external scripts.
output from the nagios server:
nsclient.log
(12.91 KiB) Downloaded 396 times
It looks like the command is taking longer than 30 seconds to run, try changing the timeout to 59 seconds to see if that works for you.
ads1923
Post by ads1923 »
I have tried to increase the timeout value before and it still fails, it fails with a different message though.
Command ran on the Nagios server:
./check_nrpe -H servername.domain.org -c check_queue_health -t 59
Result:
CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
nsclient.log
2015-05-28 12:05:38: e:c:\build\nscp\include\socket/connection.hpp:146: Failed to send data: The file handle supplied is not valid
When the timeout is set to 30:
./check_nrpe -H servername.domain.org -c check_queue_health -t 30
Result:
I am not sure if that helps point us in the right direction but it is a data point
Could you login to the Windows system and open a command prompt, change to this folder c:\Program Files\NSClient++\scripts and run the following command and post the output?
powershell ./QueueHealth.ps1
ads1923
Post by ads1923 »
Here is the output:
PS C:\Program Files\NSClient++\scripts> powershell.exe .\QueueHealth.ps1
