"Cannot Make SSL Connection"
Re: "Cannot Make SSL Connection"
Post by Box293 »
It looks like nmap needs to be installed, run this command:
yum -y install nmap
Once this is done execute the nmap command.
scheema31
Post by scheema31 »
Unfortunately I'm unable to install it either as the server entitlement does not allow it.
Are there any other suggestions?
Post by Box293 »
curl might be a way to test if the remote is listening:
curl https://git.bayleaf.com:443
scheema31
Post by scheema31 »
I was able to make this work by specifying the SSL version using "-S --ssl=VERSION" option.
Thanks for everyones help and suggestions!
