Check_log3.exe Windoes setup
gdolidze
Re: Check_log3.exe Windoes setup
Post by gdolidze »
aren't the system log, application log and security log inaccessible this way?
jolson
Attack Rabbit
Post by jolson »
Yes - check_log3 is mainly for checking a flat file that an application logs to. If you're interested in parsing out your security log, event log, and application logs you'll have to use a different plugin.
The following is one example of such a plugin: https://exchange.nagios.org/directory/P ... TK/details
Twits Blog
gdolidze
Post by gdolidze »
You guys can close this.
