Dependency not working
BanditBBS
Re: Dependency not working
Post by BanditBBS »
lmiltchev wrote:BanditBBS, there is a patch submitted that *should* fix the dependencies issues.
http://tracker.nagios.org/view.php?id=641
Sean tested it and it seemed to work, however it hasn't been tested thoroughly. Our devs need to take a look at it and see if this is not going to break something else. Anyway, as usual, if you decide to give it a try - don't test in production. :)
Thanks Ludmil. Access denied when access that issue for some reason. I can hold off for a little before I dare attempt to even test, thanks for pointing it out though!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Have you logged in? Do you have an account?
BanditBBS
Post by BanditBBS »
Yes and Yes(BanditBBS) I can see other reports, but not that one.
You should be able to view the patch now.
