service firewall check
m0le121
Re: service firewall check
Post by m0le121 »
on client:
[root@name~]# /etc/init.d/firewall status
firewall is running
[root@name~]# service firewall stop
Deleting firewall packet filter                            [  OK  ]
firewall is stopped
[root@name~]# service firewall start
Installing Firewall packet filter WARNING: All config files need .conf: /etc/modprobe.d/block-ipv6.config, it will be ignored in a future release.
                                                           [  OK  ]
[root@name~]#
on server:
[root@monitoring ~]# /etc/init.d/firewall status
-bash: /etc/init.d/firewall: No such file or directory
IF i run the code below on the nagios server:
[root@monitoring ~]# /usr/lib64/nagios/plugins/check_nrpe -H externalip.com -c firewall_check
Status 2 - Information : firewall is unknown -
value $T1 = empty
if i remove sudo in the code:
T1=$(sudo /etc/init.d/$SERVICE status)
the output on the nagios server will always be:
Status 1 - Critical : firewall is stopped
On your remote system that you want to check for the firewall status, can you run the following while the firewall is enabled and disabled and post the output back?
su nagios
/usr/lib/nagios/plugins/firewall_check.sh
echo $?
m0le121
Post by m0le121 »
Good news it works now :D
On the client side i did:
sudoedit /etc/sudoers
#Nagios user
Defaults:nrpe  !authenticate
nrpe           ALL=/sbin/service firewall status
nrpe           ALL = (root) NOPASSWD:/sbin/iptables -L -n
Defaults:nrpe  !requiretty
#Nagios user
Defaults:nagios   !authenticate
nagios            ALL=/sbin/service firewall status
nagios            ALL = (root) NOPASSWD:/sbin/iptables -L -n
Defaults:nagios   !requiretty
-- BEGIN CODE --
#!/bin/bash
# Author: Ronny Fischer
# Date: 20-07-2015
# Description: Check service firewall is running
SERVICE=firewall;
T1=$(sudo /sbin/service $SERVICE status)
RUNNING="$SERVICE is running"
STOPPED="$SERVICE is stopped"
UNKNOWN="$SERVICE is unknown"
IP_ROWS=100
IPTABLES_ROWS=$(sudo /sbin/iptables -L -n | wc -l)
FIREWALL_ROWS=$(sudo /sbin/service $SERVICE status | wc -l)
if [ "$T1" = "$RUNNING" ]; then
   echo "Status 0 - OK : $RUNNING - $IPTABLES_ROWS regels"
   exit 0
elif [ "$T1" != "$RUNNING" ] && [ $IPTABLES_ROWS -gt $IP_ROWS ] && [ $FIREWALL_ROWS -gt $IP_ROWS ]; then
   exit 0
elif [ "$T1" = "$STOPPED" ] || [ $IPTABLES_ROWS -lt $IP_ROWS ]; then
   echo "Status 1 - Critical : $STOPPED - $IPTABLES_ROWS regels"
   exit 2
else
  echo "Status 2 - Information : $UNKNOWN"
  exit 3
fi
-- END CODE --
The problem was the rights of the nagios user!
Thanks all for helping!
I'll be closing this thread now, but feel free to open another if you need anything in the future!
