# Script name: naf_initiate_ms_server_audit.ps1
# Version: v1.6.16
# Created on: 15/09/2014
# Author: D'Haese Willem
# Purpose: Initiates audit of Microsoft server
# On Github: https://github.com/willemdh/naf_initiate_ms_server_audit
# On OutsideIT: http://outsideit.net/naf-initiate-ms-server-audit
# Recent History:
# 10/06/2015 => First step to multiple outputs
# 11/06/2015 => Fixed admin, disk and service html
# 13/06/2015 => finalized ahres, services, admins
# 15/06/2015 => Finalized software and network adapters
# 16/06/2015 => Updated fieldnames and cleanup auditstruct
# Copyright:
# This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published
# by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. This program is distributed
# in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A
# PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public
# License along with this program. If not, see <http://www.gnu.org/licenses/>.
#Requires –Version 2.0
$AuditStruct = New-Object PSObject -Property @{
audit_start = (Get-Date -Format 'yyyy/MM/dd HH:mm:ss');
audit_end = '';
audit_duration = '';
audit_executer = ("$ENV:USERDOMAIN\$ENV:USERNAME")
audit_exitcode = 3;
hostname = ([System.Net.Dns]::GetHostByName((hostname.exe)).HostName).tolower();
win_test_ping = 'Unknown';
win_test_wmi = 'Unknown';
win_test_eventlog = 'Unknown';
host_version ='';
host_caption = '';
host_service_pack = '';
host_lastboot = '';
host_domain_role = '';
host_system_type = '';
host_timezone = '';
host_current_domain_controller = '';
host_registry_size = '';
host_registry_size_max = '';
host_manufacturer = '';
host_model = '';
host_physical_memory = '';
host_assettag = '';
host_serial_number = '';
host_processor_name = '';
host_processor_speed = '';
host_processor_voltage = '';
host_dns_cache = '';
hostentries = @()
$InitStruct = New-Object PSObject -Property @{
Output = 'Html';
Logstash ='';
Port = '';
outputfolder = "\\$($AuditStruct.Hostname)\C$\Nagios\NAF\NAF_Logs\Reports";
outputdate = (Get-Date -Format 'yyyyMMdd.HHmmss');
outputfile = '';
AdminGroupMembers = @();
ObjGroupName = '';
Services = '';
ServiceHtmlSvcs = '';
ServiceHtmlDisks = '';
ServiceHtmlSharePerm = '';
ShareObjs = @();
ShareColl = '';
ServiceHtmlShareNtfs = '';
ShareNtfsObjs = @();
ShareNtfsColl = '';
NetwAdapHtml = '';
RegHklm = '2147483650';
SoftwareHtml = '';
softwareobjs = @();
dnscacheobjs = @();
installedsoftreg = @();
DnsCacheHtml = '';
HostsHtml = ''
$WmiStruct = New-Object PSObject -Property @{
Win32_OperatingSystem = '';
Win32_Timezone = '';
Win32_ComputerSystem = '';
Win32_Registry = '';
Win32_SystemEnclosure = '';
Win32_Processor = '';
Win32_NetworkadapterConfiguration = '';
Win32_LogicalDisk = ''
$ErrorActionPreference = 'SilentlyContinue'
$DebugPreference = 'SilentlyContinue'
$VerbosePreference = 'SilentlyContinue'
Write-Log Verbose "Audit started on $($AuditStruct.hostname)."
#region Functions
function Test-FileLock {
param ([parameter(Mandatory=$true)][string]$Path)
$oFile = New-Object System.IO.FileInfo $Path
if ((Test-Path -Path $Path) -eq $false)
return $false
try
$oStream = $oFile.Open([System.IO.FileMode]::Open, [System.IO.FileAccess]::ReadWrite, [System.IO.FileShare]::None)
if ($oStream)
$oStream.Close()
$false
catch
# file is locked by a process.
return $true
function Write-Log {
param (
[parameter(Mandatory=$true)][string]$Log,
[parameter(Mandatory=$true)][string]$Message
$Now = Get-Date -Format 'yyyy-MM-dd HH:mm:ss,fff'
If ($Log -eq 'Verbose') {
Write-Verbose "${Now}: $Message"
else {
$Date = Get-Date -Format 'yyyy-MM-dd HH:mm:ss'
while (Test-FileLock $Log) {Start-Sleep (Get-Random -minimum 1 -maximum 10)}
"${Now}: $Message" | Out-File -filepath $Log -Append
function Get-WmiTrees {
Write-Log Verbose 'WMI Querying started on $($AuditStruct.Hostname)...'
Write-Log Verbose 'Querying Win32_OperatingSystem...'
$WmiStruct.Win32_OperatingSystem = Get-WmiObject Win32_OperatingSystem -ComputerName $AuditStruct.Hostname
Write-Log Verbose 'Querying Win32_Timezone...'
$WmiStruct.Win32_Timezone = Get-WmiObject Win32_Timezone -computername $AuditStruct.Hostname
Write-Log Verbose 'Querying Win32_ComputerSystem...'
$WmiStruct.Win32_ComputerSystem = Get-WmiObject Win32_ComputerSystem -computername $AuditStruct.Hostname
Write-Log Verbose 'Querying Win32_Registry...'
$WmiStruct.Win32_Registry = Get-WmiObject Win32_Registry -ComputerName $AuditStruct.Hostname
Write-Log Verbose 'Querying Win32_SystemEnclosure...'
$WmiStruct.Win32_SystemEnclosure = Get-WmiObject Win32_SystemEnclosure -ComputerName $AuditStruct.Hostname
Write-Log Verbose 'Querying Win32_Processor...'
$WmiStruct.Win32_Processor = Get-WmiObject Win32_Processor -ComputerName $AuditStruct.Hostname
Write-Log Verbose 'Querying win32_NetworkadapterConfiguration...'
$WmiStruct.Win32_NetworkadapterConfiguration = Get-WmiObject win32_NetworkadapterConfiguration -computername $AuditStruct.Hostname -Filter 'ipenabled = "true"'
Write-Log Verbose 'Querying Win32_Logicaldisk...'
$WmiStruct.Win32_LogicalDisk = Get-WmiObject Win32_Logicaldisk -ComputerName $AuditStruct.Hostname -Fi 'DriveType=3' |
Select-Object @{Name='Computername'; Expression={$_.SystemName}}, DeviceId,
@{Name='SizeGB';Expression={'{0:N2}' -f ($_.Size/1GB)}},
@{Name='FreeGB';Expression={'{0:N2}' -f ($_.Freespace/1GB)}},
@{Name='UsedGB';Expression={'{0:N2}' -f (($_.Size-$_.FreeSpace)/1GB)}},
@{Name='PerFree';Expression={'{0:P2}' -f ($_.FreeSpace/$_.Size)}}
Write-Log Verbose 'WMI Querying end...'
function Set-ProcessPriority {
param($ProcessName = $(throw 'Enter process name'), $Priority = 'Normal')
Write-Log Verbose "Setting process priority of $ProcessName to $Priority..."
Get-Process -processname $ProcessName | foreach { $_.PriorityClass = $Priority }
function Test-Paths {
Write-Log Verbose "Testing path for writing `"`b`b$($InitStruct.OutputFolder)\$($AuditStruct.Hostname)`.$($InitStruct.OutputDate).html`"..."
$InitStruct.OutputFile = "\\$($InitStruct.OutputFolder)\$($AuditStruct.Hostname)`.$($InitStruct.OutputDate).html"
if (!(Test-Path -path $InitStruct.OutputFolder)) {
try {
New-Item -Path $InitStruct.OutputFolder -Type directory -Force
catch {
Write-Log Verbose "Error creating directory `"`b`b$($InitStruct.OutputFolder)`" on $($AuditStruct.Hostname)"
else {
Write-Log Verbose "Directory `"`b`b$($InitStruct.OutputFolder)`" created on $($AuditStruct.Hostname)"
Function Send-JsonOverTcp {
param ( [ValidateNotNullOrEmpty()]
[string] $NagiosLogServer,
[int] $Port,
$JsonObject)
$JsonString = $JsonObject -replace "`n",' ' -replace "`r",' '
$Ip = [System.Net.Dns]::GetHostAddresses($NagiosLogServer)
$Address = [System.Net.IPAddress]::Parse($Ip)
$Socket = New-Object System.Net.Sockets.TCPClient($Address,$Port)
$Stream = $Socket.GetStream()
$Writer = New-Object System.IO.StreamWriter($Stream)
$Writer.WriteLine($JsonString)
$Writer.Flush()
$Stream.Close()
$Socket.Close()
function Get-HostEntries {
[CmdletBinding()]
param (
[Parameter(Mandatory=$false)][String]$Filter
function New-ObjectHostEntry{
param(
[string]$IP,
[string]$DNS
IP = $IP
DNS = $DNS
Write-Log Verbose 'Querying hosts file...'
$Entries = $(get-content "$env:windir\System32\drivers\etc\hosts") | % {
if (!$_.StartsWith('#') -and $_ -ne '') {
$IP = ([regex]'(([2]([0-4][0-9]|[5][0-5])|[0-1]?[0-9]?[0-9])[.]){3}(([2]([0-4][0-9]|[5][0-5])|[0-1]?[0-9]?[0-9]))').match($_).value
$DNS = ($_ -replace $IP, '') -replace '\s+',''
if ($Filter -and (($IP -match $Filter) -or ($DNS -match $Filter))) {
New-ObjectHostEntry -IP $IP -DNS $DNS
elseif ($Filter -eq '') {
if ($Entries -ne $Null) {
$Entries
else {
Write-Log Verbose 'No entries found in host file...'
Write-Log Verbose 'Hosts file scanned.'
function Start-Audit {
# Connectivity tests
if ($AuditStruct.win_test_ping -eq '') {
$PingResult = Test-Connection -ComputerName $AuditStruct.Hostname -Count 1 -Quiet
if ($PingResult) {
$AuditStruct.win_test_ping = 'Succeeded'
else {
$AuditStruct.win_test_ping = 'Failed'
Write-Host "CRITICAL: Ping to $Value failed! Please provide valid reachable hostname."
exit 1
Write-Log Verbose "Testing WMI on $($AuditStruct.Hostname)..."
$WmiTest = Get-WmiObject -Query "Select * from Win32_PingStatus where Address = '$($AuditStruct.Hostname)'"
if($WmiTest) {
$AuditStruct.win_test_wmi = 'Succeeded'
else {
$AuditStruct.win_test_wmi = 'Failed'
Write-Log Verbose "Testing Eventlog access on $($AuditStruct.Hostname)..."
$EventlogTest = Get-EventLog System -ComputerName $AuditStruct.Hostname -Newest 1
if($EventlogTest) {
$AuditStruct.win_test_eventlog = 'Succeeded'
else {
$AuditStruct.win_test_eventlog = 'Failed'
# System information
Write-Log Verbose 'Querying system information...'
$AuditStruct.host_version = $WmiStruct.Win32_OperatingSystem.Version
$AuditStruct.host_caption = $WmiStruct.Win32_OperatingSystem.Caption
$AuditStruct.host_service_pack = $WmiStruct.Win32_OperatingSystem.ServicePackMajorVersion
$AuditStruct.host_lastboot = ($WmiStruct.Win32_OperatingSystem.ConvertToDateTime($WmiStruct.Win32_OperatingSystem.LastBootUpTime)).ToString('dd/MM/yyyy HH:mm:ss')
switch ($WmiStruct.Win32_ComputerSystem.DomainRole) {
0 { $AuditStruct.host_domain_role = 'Standalone Workstation' }
1 { $AuditStruct.host_domain_role = 'Member Workstation' }
2 { $AuditStruct.host_domain_role = 'Standalone Server' }
3 { $AuditStruct.host_domain_role = 'Member Server' }
4 { $AuditStruct.host_domain_role = 'Domain Controller' }
5 { $AuditStruct.host_domain_role = 'Domain Controller' }
default { $AuditStruct.host_domain_role = 'Information not available' }
switch ($WmiStruct.Win32_ComputerSystem.PCSystemType) {
1 { $AuditStruct.host_system_type = 'Desktop' }
2 { $AuditStruct.host_system_type = 'Mobile / Laptop' }
3 { $AuditStruct.host_system_type = 'Workstation' }
4 { $AuditStruct.host_system_type = 'Enterprise Server' }
5 { $AuditStruct.host_system_type = 'Small Office and Home Office (SOHO) Server' }
6 { $AuditStruct.host_system_type = 'Appliance PC' }
7 { $AuditStruct.host_system_type = 'Performance Server' }
8 { $AuditStruct.host_system_type = 'Maximum' }
default { $AuditStruct.host_system_type = 'Not a known Product Type' }
$AuditStruct.host_timezone = $WmiStruct.Win32_Timezone.Description
$AuditStruct.host_current_domain_controller = $env:LOGONSERVER -replace '\\', ''
$AuditStruct.host_registry_size = $WmiStruct.Win32_Registry.CurrentSize
$AuditStruct.host_registry_size_max = $WmiStruct.Win32_Registry.MaximumSize
if (!$AuditStruct.host_registry_size_max) {$AuditStruct.host_registry_size_max = 'Undefined'}
$AuditStruct.host_manufacturer = $WmiStruct.Win32_ComputerSystem.Manufacturer
$AuditStruct.host_model = $WmiStruct.Win32_ComputerSystem.Model
$AuditStruct.host_physical_memory = $WmiStruct.Win32_ComputerSystem.TotalPhysicalMemory
$AuditStruct.host_assettag = $WmiStruct.Win32_SystemEnclosure.SMBIOSAssetTag
$AuditStruct.host_serial_number = $WmiStruct.Win32_SystemEnclosure.SerialNumber
$AuditStruct.host_processor_name = $WmiStruct.Win32_Processor.Name
$AuditStruct.host_processor_speed = $WmiStruct.Win32_Processor.CurrentClockSpeed
$AuditStruct.host_processor_voltage = $WmiStruct.Win32_Processor.CurrentVoltage
foreach ($HostLogicalDisk in $WmiStruct.Win32_LogicalDisk) {
$DrvDeviceId = ($HostLogicalDisk.DeviceId -replace ':','').tolower()
$AuditStruct | Add-Member -type NoteProperty -name win_drv_${DrvDeviceId}_name -Value $DrvDeviceId
$AuditStruct | Add-Member -type NoteProperty -name win_drv_${DrvDeviceId}_totalgb -Value $HostLogicalDisk.SizeGB
$AuditStruct | Add-Member -type NoteProperty -name win_drv_${DrvDeviceId}_freegb -Value $HostLogicalDisk.FreeGB
$AuditStruct | Add-Member -type NoteProperty -name win_drv_${DrvDeviceId}_usedgb -Value $HostLogicalDisk.UsedGB
$AuditStruct | Add-Member -type NoteProperty -name win_drv_${DrvDeviceId}_freeperc -Value $HostLogicalDisk.PerFree
$InitStruct.ServiceHtmlDisks += "<tr><td>$($HostLogicalDisk.DeviceId)</td><td>$($HostLogicalDisk.SizeGB) GB</td> <td>$($HostLogicalDisk.FreeGB) GB</td><td>$($HostLogicalDisk.UsedGB) GB</td> <td>$($HostLogicalDisk.PerFree)</td> </tr>"
# Administrator information
Write-Log Verbose 'Querying administrators group members...'
$ObjSID = New-Object System.Security.Principal.SecurityIdentifier('S-1-5-32-544')
$Objgroup = $objSID.Translate( [System.Security.Principal.NTAccount])
$InitStruct.ObjGroupName = ($objgroup.Value).Split('\')[1]
$AdsiGroup =[ADSI]"WinNT://$($AuditStruct.Hostname)/$($InitStruct.ObjGroupName)"
$InitStruct.AdminGroupMembers = @($AdsiGroup.psbase.Invoke('Members'))
# Service information
Write-Log Verbose 'Querying system services...'
$InitStruct.Services = Get-Service -ComputerName $AuditStruct.Hostname
foreach ($service in $InitStruct.Services) {
$StartupType = Get-WmiObject -Query "Select StartMode From Win32_Service Where Name='$($service.Name)'"
$servicelower = ($service.Name -replace '\s','').ToLower()
$servicestate = "$($Service.Status)"
$AuditStruct | Add-Member -type NoteProperty -name win_svc_${servicelower}_name -Value $service.DisplayName
$AuditStruct | Add-Member -type NoteProperty -name win_svc_${servicelower}_status -Value $servicestate
$AuditStruct | Add-Member -type NoteProperty -name win_svc_${servicelower}_startuptype -Value $StartupType.Startmode
$InitStruct.ServiceHtmlSvcs += "<tr><td>$($service.Name)</td>
<td>$($service.DisplayName)</td>
<td>$servicestate</td>
<td>$($StartupType.StartMode)</td>
</tr>"
# Share information
Write-Log Verbose 'Querying system share permissions...'
$InitStruct.ShareObjs = Get-SharedFolderPermission $AuditStruct.Hostname
$LastShare = ''
foreach ($ShareObj in $InitStruct.ShareObjs){
$CurrentShare = ($ShareObj.SharedFolderName -replace '\s','').ToLower()
if (($LastShare -eq '') -or ($CurrentSHare -eq $LastShare)) {
$InitStruct.ShareColl += "{$($ShareObj.SharedFolderName) {$($ShareObj.SecurityPrincipal)},{$($ShareObj.FileSystemRights)},{$($ShareObj.AccessControlType)}}"
else {
$AuditStruct | Add-Member -type NoteProperty -name win_share_$LastShare -Value $InitStruct.ShareColl
$InitStruct.ShareColl = ''
$InitStruct.ServiceHtmlSharePerm += "<tr>
<td>$($ShareObj.SharedFolderName)</td>
<td>$($ShareObj.SecurityPrincipal)</td>
<td>$($ShareObj.FileSystemRights)</td>
<td>$($ShareObj.AccessControlType)</td>
</tr>"
$LastShare = $CurrentShare
# Share NTFS information
Write-Log Verbose 'Querying share NTFS permissions...'
$InitStruct.ShareNtfsObjs = Get-SharedFolderNTFSPermission $AuditStruct.Hostname
$LastShareNtfs = ''
foreach ($ShareNtfsObj in $InitStruct.ShareNtfsObjs){
$CurrentShareNtfs = ($ShareNtfsObj.SharedFolderName -replace '\s','_').ToLower()
if (($LastShareNtfs -eq '') -or ($CurrentShareNtfs -eq $LastShareNtfs)) {
$InitStruct.ShareNtfsColl += "{$($ShareNtfsObj.SharedFolderName) {$($ShareNtfsObj.SecurityPrincipal)},{$($ShareNtfsObj.FileSystemRights)},{$($ShareNtfsObj.AccessControlType)},{$($ShareNtfsObj.AccessControlFlags)}}"
else {
$AuditStruct | Add-Member -type NoteProperty -name win_share_ntfs_$LastShareNtfs -Value $InitStruct.ShareNtfsColl
$InitStruct.ShareNtfsColl = ''
$InitStruct.ServiceHtmlShareNtfs += "<tr>
<td>$($ShareNtfsObj.SharedFolderName)</td>
<td>$($ShareNtfsObj.SecurityPrincipal)</td>
<td>$($ShareNtfsObj.FileSystemRights)</td>
<td>$($ShareNtfsObj.AccessControlType)</td>
<td>$($ShareNtfsObj.AccessControlFlags)</td>
</tr>"
$LastShareNtfs = $CurrentShareNtfs
# Network adapter information
Write-Log Verbose 'Querying system network adapters...'
foreach ($HostAdapter in $WmiStruct.Win32_NetworkadapterConfiguration) {
$CurrentAdapter = ($HostAdapter.Description -replace '\s','_').ToLower()
$AuditStruct | Add-Member -type NoteProperty -name win_nic_${CurrentAdapter}_name -Value $($HostAdapter.Description)
$AuditStruct | Add-Member -type NoteProperty -name win_nic_${CurrentAdapter}_ips -Value $($HostAdapter.IPAddress)
$AuditStruct | Add-Member -type NoteProperty -name win_nic_${CurrentAdapter}_dhcp -Value $($HostAdapter.DHCPEnabled)
$AuditStruct | Add-Member -type NoteProperty -name win_nic_${CurrentAdapter}_subnet -Value $($HostAdapter.Subnet)
$AuditStruct | Add-Member -type NoteProperty -name win_nic_${CurrentAdapter}_gateway -Value $($HostAdapter.DefaultIPGateway)
$InitStruct.NetwAdapHtml += "<tr>
<td>$($HostAdapter.Description)</td>
<td>Adapter IP Address</td>
<td>$($HostAdapter.IPAddress)</td></tr></tbody>
<tbody><tr>
<td>Adapter DHCP</td>
<td>$($HostAdapter.DHCPEnabled)</td>
</tr></tbody>
<tbody><tr>
<td>Adapter Subnet Mask</td>
<td>$($HostAdapter.IPSubnet)</td>
</tr></tbody>
<tbody><tr>
<td>Adapter Gateway</td>
<td>$($HostAdapter.DefaultIPGateway)</td>
</tr></tbody>
<tbody><tr>
<td>Adapter MAC Address</td>
<td>$($HostAdapter.MACAddress)</td>
</tr></tbody>
<tbody><tr>
<td>Adapter DNS Servers</td>
<td>$($HostAdapter.DNSServerSearchOrder)</td>
</tr>"
# Software information
$Wmi = [wmiclass]"\\$($AuditStruct.Hostname)\root\default:stdRegProv"
$RegClass = Get-WmiObject -Namespace 'Root\Default' -List -ComputerName $AuditStruct.Hostname | Where-Object { $_.Name -eq 'StdRegProv' }
$IEKey = 'SOFTWARE\Microsoft\Internet Explorer'
$IEVersion = ($regclass.GetStringValue($InitStruct.RegHklm,$IEKey,'Version')).sValue
$InitStruct.SoftwareObjs += New-Object -TypeName PSCustomObject -Property @{
'Name' = 'Internet Explorer'
'Method'= 'Registry Microsoft\Internet Explorer Key'
'Version' = $IEVersion
'Vendor' = 'Microsoft'
'InstallDate' = 'unknown'}
$McAfeeKey='SOFTWARE\McAfee\AVEngine'
$McAfeeDATVersion = ($RegClass.GetDWORDValue($InitStruct.RegHklm,$McAfeeKey,'AVDATVersion')).uValue
$McAfeeEngineVerMajor = ($RegClass.GetDWORDValue($InitStruct.RegHklm,$McAfeeKey,'EngineVersionMajor')).uValue
$McAfeeEngineVerMinor = ($RegClass.GetDWORDValue($InitStruct.RegHklm,$McAfeeKey,'EngineVersionMinor')).uValue
'Name' = 'McAfee Antivirus DAT'
'Method'= 'Registry McAfee\AVEngine Key'
'Version' = $McAfeeDATVersion
'Vendor' = 'McAfee'
'Name' = 'McAfee Antivirus Engine'
'Version' = $McAfeeEngineVerMajor
'Vendor' = 'McAfee'
$InitStruct.InstalledSoftReg = get-installedsoftware $AuditStruct.Hostname
foreach ($InstalledSoftware in $InitStruct.InstalledSoftReg) {
'Name' = $InstalledSoftware.Name
'Method'= 'Registry'
'Version' = $InstalledSoftware.Version
'Vendor' = $InstalledSoftware.Publisher
'InstallDate' = $InstalledSoftware.InstallDate
'Size' = $InstalledSoftware.EstimatedSize
$InitStruct.SoftwareObjs = $InitStruct.SoftwareObjs | Sort-Object Name, Method
foreach ($SoftwareObj in $InitStruct.SoftwareObjs) {
$CurrentSoftware = ($SoftwareObj.Name -replace '\s','_').ToLower()
$AuditStruct | Add-Member -type NoteProperty -name win_prog_${CurrentSoftware}_name -Value "{{$($SoftwareObj.Name)}{$($SoftwareObj.Version)}{$($SoftwareObj.Size)}}"
$InitStruct.SoftwareHtml += "<tr>
<td>$($SoftwareObj.Name)</td>
<td>$($SoftwareObj.Method)</td>
<td>$($SoftwareObj.Version)</td>
<td>$($SoftwareObj.Vendor)</td>
<td>$($SoftwareObj.InstallDate)</td>
<td>$($SoftwareObj.Size) MB</td>
</tr>"
# DNS Cache
$InitStruct.DnsCacheObjs = Get-DNSClientCache
foreach ($DnsCacheObj in $InitStruct.DnsCacheObjs) {
$AuditStruct.host_dns_cache += "((Name:$($DnsCacheObj.Name))(Section:$($DnsCacheObj.Section))(TTL:$($DnsCacheObj.TTL))(Type:$($DnsCacheObj.Type))(Length:$($DnsCacheObj.Length))(Hostrecord:$($DnsCacheObj.HostRecord))) "
$InitStruct.DnsCacheHtml += "<tr>
<td>$($DnsCacheObj.Name)</td>
<td>$($DnsCacheObj.Section)</td>
<td>$($DnsCacheObj.TTL)</td>
<td>$($DnsCacheObj.Type)</td>
<td>$($DnsCacheObj.Length)</td>
<td>$($DnsCacheObj.HostRecord)</td>
</tr></tbody>"
# Hosts File Entries
$AuditStruct.HostEntries = Get-HostEntries
foreach ($HostEntry in $AuditStruct.HostEntries) {
$InitStruct.HostsHtml += "<tr>
<td>$($HostEntry.IP)</td>
<td>$($HostEntry.DNS)</td>
</tr>"
$AuditStruct.audit_end = (Get-Date -Format 'yyyy/MM/dd HH:mm:ss')
$AuditDuration = New-TimeSpan –Start $AuditStruct.audit_start –End $AuditStruct.audit_end
$AuditStruct.audit_duration = '{0:HH:mm:ss}' -f ([datetime]$AuditDuration.Ticks)
Function Get-SharedFolderPermission {
Param([String]$Computername)
$PingResult = Test-Connection -ComputerName $ComputerName -Count 1 -Quiet
if($PingResult)
if($Credential)
$SharedFolderSecs = Get-WmiObject -Class Win32_LogicalShareSecuritySetting -ComputerName $ComputerName -Credential $Credential -ErrorAction SilentlyContinue
else
$SharedFolderSecs = Get-WmiObject -Class Win32_LogicalShareSecuritySetting -ComputerName $ComputerName -ErrorAction SilentlyContinue
foreach ($SharedFolderSec in $SharedFolderSecs)
$Objs = @()
$SecDescriptor = $SharedFolderSec.GetSecurityDescriptor()
foreach($DACL in $SecDescriptor.Descriptor.DACL)
$DACLDomain = $DACL.Trustee.Domain
$DACLName = $DACL.Trustee.Name
if($DACLDomain -ne $null)
$UserName = "$DACLDomain\$DACLName"
else
$UserName = "$DACLName"
$Properties = @{'ComputerName' = $ComputerName
'ConnectionStatus' = 'Success'
'SharedFolderName' = $SharedFolderSec.Name
'SecurityPrincipal' = $UserName
'FileSystemRights' = [Security.AccessControl.FileSystemRights]$($DACL.AccessMask -as [Security.AccessControl.FileSystemRights])
'AccessControlType' = [Security.AccessControl.AceType]$DACL.AceType}
$SharedACLs = New-Object -TypeName PSObject -Property $Properties
$Objs += $SharedACLs
$Objs|Select-Object ComputerName,ConnectionStatus,SharedFolderName,SecurityPrincipal,FileSystemRights,AccessControlType
else
'ConnectionStatus' = 'Fail'
'SharedFolderName' = 'Not Available'
'SecurityPrincipal' = 'Not Available'
'FileSystemRights' = 'Not Available'
'AccessControlType' = 'Not Available'}
Function Get-SharedFolderNTFSPermission {
if($PingResult)
#check the credential whether trigger
if($Credential)
$SharedFolders = Get-WmiObject -Class Win32_Share `
else
foreach($SharedFolder in $SharedFolders)
$Objs = @()
$SharedFolderPath = [regex]::Escape($SharedFolder.Path)
if($Credential)
$SharedNTFSSecs = Get-WmiObject -Class Win32_LogicalFileSecuritySetting `
-Filter "Path='$SharedFolderPath'" -ComputerName $ComputerName -Credential $Credential
else
$SecDescriptor = $SharedNTFSSecs.GetSecurityDescriptor()
else
#customize the property
'SharedFolderName' = $SharedFolder.Name
'AccessControlFlags' = [Security.AccessControl.AceFlags]$DACL.AceFlags}
$SharedNTFSACL = New-Object -TypeName PSObject -Property $Properties
$Objs += $SharedNTFSACL
$Objs |Select-Object ComputerName,ConnectionStatus,SharedFolderName,SecurityPrincipal,FileSystemRights,AccessControlType,AccessControlFlags -Unique
else
'AccessControlFlags' = 'Not Available'}
Function Get-InstalledSoftware{
Param([String[]]$Computers)
If (!$Computers) {$Computers = $ENV:ComputerName}
$Base = New-Object PSObject;
$Base | Add-Member Noteproperty ComputerName -Value $Null;
$Base | Add-Member Noteproperty Name -Value $Null;
$Base | Add-Member Noteproperty Publisher -Value $Null;
$Base | Add-Member Noteproperty InstallDate -Value $Null;
$Base | Add-Member Noteproperty EstimatedSize -Value $Null;
$Base | Add-Member Noteproperty Version -Value $Null;
$Base | Add-Member Noteproperty Wow6432Node -Value $Null;
$Results = New-Object System.Collections.Generic.List[System.Object];
ForEach ($ComputerName in $Computers){
$Registry = $Null;
Try{$Registry = [Microsoft.Win32.RegistryKey]::OpenRemoteBaseKey([Microsoft.Win32.RegistryHive]::LocalMachine,$ComputerName);}
Catch{Write-Host -ForegroundColor Red "$($_.Exception.Message)";}
If ($Registry){
$UninstallKeys = $Null;
$SubKey = $Null;
$UninstallKeys = $Registry.OpenSubKey('Software\Microsoft\Windows\CurrentVersion\Uninstall',$False);
$UninstallKeys.GetSubKeyNames()|%{
$SubKey = $UninstallKeys.OpenSubKey($_,$False);
$DisplayName = $SubKey.GetValue('DisplayName');
If ($DisplayName.Length -gt 0){
$Entry = $Base | Select-Object *
$Entry.ComputerName = $ComputerName;
$Entry.Name = $DisplayName.Trim();
$Entry.Publisher = $SubKey.GetValue('Publisher');
[ref]$ParsedInstallDate = Get-Date
$Entry.InstallDate = $SubKey.GetValue('InstallDate')
$Entry.EstimatedSize = [Math]::Round($SubKey.GetValue('EstimatedSize')/1KB,1);
$Entry.Version = $SubKey.GetValue('DisplayVersion');
[Void]$Results.Add($Entry);
If ([IntPtr]::Size -eq 8){
$UninstallKeysWow6432Node = $Null;
$SubKeyWow6432Node = $Null;
$UninstallKeysWow6432Node = $Registry.OpenSubKey('Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall',$False);
If ($UninstallKeysWow6432Node) {
$UninstallKeysWow6432Node.GetSubKeyNames()|%{
$SubKeyWow6432Node = $UninstallKeysWow6432Node.OpenSubKey($_,$False);
$DisplayName = $SubKeyWow6432Node.GetValue('DisplayName');
$Entry.Publisher = $SubKeyWow6432Node.GetValue('Publisher');
$Entry.InstallDate = $SubKeyWow6432Node.GetValue('InstallDate')
$Entry.EstimatedSize = [Math]::Round($SubKeyWow6432Node.GetValue('EstimatedSize')/1KB,1);
$Entry.Version = $SubKeyWow6432Node.GetValue('DisplayVersion');
$Entry.Wow6432Node = $True;
$Results
Function Get-DNSClientCache{
$DNSCache = @()
Invoke-Expression 'IPConfig /DisplayDNS' |
Select-String -Pattern 'Record Name' -Context 0,5 |
$Record = New-Object PSObject -Property @{
Name=($_.Line -Split ':')[1]
Type=($_.Context.PostContext[0] -Split ':')[1]
TTL=($_.Context.PostContext[1] -Split ':')[1]
Length=($_.Context.PostContext[2] -Split ':')[1]
Section=($_.Context.PostContext[3] -Split ':')[1]
HostRecord=($_.Context.PostContext[4] -Split ':')[1]
$DNSCache +=$Record
return $DNSCache
Function Initialize-Args {
Param (
[Parameter(Mandatory=$True)]$Args
try {
For ( $i = 0; $i -lt $Args.count; $i++ ) {
$CurrentArg = $Args[$i].ToString()
if ($i -lt $Args.Count-1) {
$Value = $Args[$i+1];
If ($Value.Count -ge 2) {
foreach ($Item in $Value) {
Test-Strings $Item | Out-Null
else {
Test-Strings $Value | Out-Null
} else {
$Value = ''
switch -regex -casesensitive ($CurrentArg) {
"^(-H|--Hostname)$" {
if ($Value -ne ([System.Net.Dns]::GetHostByName((hostname.exe)).HostName).tolower() -and $Value -ne 'localhost') {
$PingResult = Test-Connection -ComputerName $Value -Count 1 -Quiet
if ($PingResult) {
$AuditStruct.Hostname = $Value
$i++
else {
exit 1
else {
$i++
"^(-O|--Output)$" {
if (($value -match 'Html' -or $value -match 'Logstash')) {
$InitStruct.Output = $value
} else {
throw "Some issue with output value. Value given is $value."
$i++
"^(-L|--Logstash)$" {
if ($value -match "^[a-zA-Z0-9_.]+$") {
$InitStruct.Logstash = $value
} else {
throw "Some issues with logstash server value. Value given is $value."
$i++
"^(-p|--Port)$" {
if (($value -match "^[0-9]+$")-and ([int]$value -lt 65000)) {
$InitStruct.port = $value
} else {
throw "Some issues with port value. Value given is $value."
$i++
"^(-h|--Help)$" {
Write-Help
default {
throw "Illegal arguments detected: $_"
} catch {
Write-Host "UNKNOWN: $_"
Exit 2
Function Test-Strings {
Param ( [Parameter(Mandatory=$True)][string]$String )
$BadChars=@("``", '|', ';', "`n")
$BadChars | ForEach-Object {
If ( $String.Contains("$_") ) {
Write-Host 'Unknown: String contains illegal characters.'
Exit 2
Return $true
Function Write-Help {
Write-Host @"
naf_initiate_ms_server_audit.ps1:
This script is designed to audit a MS server and output result to html.
Arguments:
-H | --Hostname => Optional hostname of remote system, default is localhost, not yet tested on remote host.
-O | --Output => Audit output, currently to html and to Logstash or equivalents
-L | --Logstash => Logstash server to send audit to
-p | --Port => Logstash server port to send audit to
-h | --Help => Print this help output.
Exit 3
#endregion Functions
# Main
Set-ProcessPriority scripteditor BelowNormal
if($Args.count -ge 1){
Initialize-Args $Args
Test-Paths
Get-WmiTrees
Start-Audit
# Write-Host $AuditJson
if ($InitStruct.Output -eq 'Html') {
"<!DOCTYPE html>
<html>
<head>
<meta charset=""utf-8"">
<meta name=""description"" content=""This generated html page will display available information for the server passed as a parameter."">
<style type=""text/css"">
table {
border: 5px solid grey ;
th, td {
padding: 5px 10px;
border: 1px solid #999;
text-align: left;
th {
background-color: #eee;
</style>
</head>
<body>
<h1>NAF - Server Audit</h1>
<br><hr>
<h3>Audit information</h3>
<table><thead><tr>
<th>Start Date</th>
<th>End Date</th>
<th>Duration</th>
<th>Executer</th>
</tr></thead>
<tbody><tr>
<td>$($AuditStruct.audit_start)</td>
<td>$($AuditStruct.audit_end)</td>
<td>$($AuditStruct.audit_duration)</td>
<td>$($AuditStruct.audit_executer)</td>
</tr></tbody>
</table>
<br><hr>
<h3>Connectivity Test</h3>
<table><thead><tr>
<th>Test</th>
<th>Result</th>
</tr></thead>
<tbody><tr>
<td>Ping</td>
<td>$($AuditStruct.win_test_ping)</td>
</tr></tbody>
<tbody><tr>
<td>WMI</td>
<td>$($AuditStruct.win_test_wmi)</td>
</tr></tbody>
<tbody><tr>
<td>Eventlog</td>
<td>$($AuditStruct.win_test_eventlog)</td>
</tr></tbody>
</table>
<br><hr>
<h3>System Information</h3>
<table>
<thead><tr><th>Query</th><th>Result</th></tr></thead>
<tbody><tr><td>System Version </td><td>$($AuditStruct.host_version)</td></tr></tbody>
<tbody><tr><td>System Caption </td><td>$($AuditStruct.host_caption)</td></tr></tbody>
<tbody><tr><td>System Service Pack </td><td>$($AuditStruct.host_service_pack)</td></tr></tbody>
<tbody><tr><td>System Last Boot </td><td>$($AuditStruct.host_lastboot)</td></tr></tbody>
<tbody><tr><td>System Domain Role </td><td>$($AuditStruct.host_domain_role)</td></tr></tbody>
<tbody><tr><td>System Type </td><td>$($AuditStruct.host_system_type)</td></tr></tbody>
<tbody><tr><td>System Time Zone </td><td>$($AuditStruct.host_timezone)</td></tr></tbody>
<tbody><tr><td>System Domain Controller</td><td>$($AuditStruct.host_current_domain_controller)</td></tr></tbody>
<tbody><tr><td>System Current Registry Size</td><td>$($AuditStruct.host_registry_size)</td></tr></tbody>
<tbody><tr><td>System Maximum Registry Size</td><td>$($AuditStruct.host_registry_size_max)</td></tr></tbody>
<tbody><tr><td>System Manufacturer</td><td>$($AuditStruct.host_manufacturer)</td></tr></tbody>
<tbody><tr><td>System Model</td><td>$($AuditStruct.host_model)</td></tr></tbody>
<tbody><tr><td>System Total Physical Memory</td><td>$($AuditStruct.host_physical_memory)</td></tr></tbody>
<tbody><tr><td>System Asset Tag</td><td>$($AuditStruct.host_assettag)</td></tr></tbody>
<tbody><tr><td>System Serial Number</td><td>$($AuditStruct.host_serial_number)</td></tr></tbody>
<tbody><tr><td>System Processor Name</td><td>$($AuditStruct.host_processor_name)</td></tr></tbody>
<tbody><tr><td>System Processor Speed</td><td>$($AuditStruct.host_processor_speed)</td></tr></tbody>
<tbody><tr><td>System Processor Voltage</td><td>$($AuditStruct.host_processor_voltage)</td></tr></tbody>
</table>
<br> <hr>
<h3>Disk Information</h3>
<table><thead><tr>
<th>Drive Name</th>
<th>Total Size (GB)</th>
<th>Free GB</th><th>Used GB</th>
<th>Percentage Free</th>
</tr></thead>
<tbody>
$($InitStruct.ServiceHtmlDisks)
</tbody>
</table>
<br><hr>
<h3>Local Group Members</h3>
<table><thead><tr>
<th>Group Name</th>
<th>Group Members</tr>
</thead>" | out-file -Append $InitStruct.OutputFile
$InitStruct.AdminGroupMembers | foreach {
$obj = new-object psobject -Property @{LocalAdmin = $_.GetType().InvokeMember('Name', 'GetProperty', $null, $_, $null)}
"<tbody><tr>
<td>$($InitStruct.ObjGroupName)</td>
<td>$($obj.LocalAdmin)</td>
</tr></tbody>" | out-file -Append $InitStruct.OutputFile
"</table><br><hr>
<h3>Service Configuration</h3>
<table><thead><tr>
<th>Service Name</th>
<th>Display Name</th><th>Status</th>
<th>Startup Type</th>
</tr></thead><tbody>
$($InitStruct.ServiceHtmlSvcs)
</tbody></table><br><hr>
<h3>Share Permissions</h3>
<table><thead><tr><th>Sharename</th>
<th>Security Principal</th>
<th>File System Rights</th>
<th>Access Control Type</th>
</tr></thead>
<tbody>
$($InitStruct.ServiceHtmlSharePerm)
</tobdy>
</table><br><hr>
<h3>Share NTFS Permissions</h3>
<table><thead><tr>
<th>Sharename</th>
<th>Access Control Flags</th>
</tr></thead>
<tbody>
$($InitStruct.ServiceHtmlShareNtfs)
</tbody>
</table><br><hr>
<h3>Network Adapters</h3>
<table><thead><tr>
<th>Adapter Name</th>
<th>Adapter Query</th>
<th>Adapter Query Result</th>
</tr></thead>
<tbody>
$($InitStruct.NetwAdapHtml)
</tbody>
</table><br><hr>
<h3>Software Information</h3>
<table><thead><tr>
<th>Software Name</th>
<th>Method</th>
<th>Version</th>
<th>Vendor</th>
<th>Install Date</th>
<th>Estimated Size</th>
$($InitStruct.SoftwareHtml)
<h3>DNS Cache</h3>
<table><thead><tr>
<th>Name</th>
<th>Section</th>
<th>TTL</th>
<th>Type</th>
<th>Length</th>
<th>Host Record</th>
$($InitStruct.DnsCacheHtml)
</tbody>
</table><br><hr>
<h4>Hosts file</h3>
<table><thead><tr>
<th>IP</th>
<th>DNS</th>
</tr></thead>
<tbody>
$($InitStruct.HostsHtml)
</tbody>
</table><br><hr>
</html>" | out-file -append $InitStruct.OutputFile
if ($InitStruct.Output -eq 'Logstash') {
$AuditJson = $AuditStruct | ConvertTo-Json
Send-JsonOverTcp $InitStruct.Logstash $InitStruct.Port $Auditjson
Set-ProcessPriority scripteditor Normal
Write-Host "OK: Audit of $($AuditStruct.Hostname) succeeded in $($AuditStruct.audit_duration) time."
exit 0Code: Select all
tcp {
type => 'powershell-audit'
port => 5600
codec => json {
charset => 'UTF-8'
}./naf_initiate_ms_server_audit.ps1 -L <nlsserver> -p 5600 -O Logstash
Any help or tip is welcome. One script run takes about 25 seconds.
Grtz
Willem
