check_mssql_health doesn't run as nagios user
Re: check_mssql_health doesn't run as nagios user
Sounds good, it's usually better to install perl modules with yum, it makes upgrading a lot easier because yum doesn't know about perl modules installed with cpan.
Hi ssax,
I tried compileing the plugin again as you suggested however, I get the same error.
I then tried to install Sybase from yum, however, I got the below error
Is there away to remove the cpan Sybase and install from yum? do I need to add another repo to install Sybase from yum? I had a nightmare installing Sybase the first time round!
Thanks for the help
Loaded plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: centos.muzzy.org.uk
* epel: www.mirrorservice.org
* extras: mirror.as29550.net
* updates: mirror.as29550.net
No package perl-DBD-Sybase available.
Error: Nothing to do
Thanks for the help
This package should be available from the rpmforge repo...
What is the output of the following command?
yum search perl | grep Sybase
perl-DBD-Sybase.x86_64 : Perl module named DBD-SybaseCode: Select all
yum provides perl-DBD-Sybase
* base: mirror.us.leaseweb.net
* epel: mirror.steadfast.net
* extras: mirror.raystedman.net
* rpmforge: mirror.nexcess.net
* updates: ftpmirror.your.org
perl-DBD-Sybase-1.10-1.el6.rf.x86_64 : Perl module named DBD-Sybase
Repo : rpmforgeCode: Select all
yum repolist -vBe sure to check out our Knowledgebase for helpful articles and solutions!
Running `yum search perl | grep Sybase` doesn't return anything, see below
I have installed the rpmforge repo by following the below link for x64 CentoOS 7
http://www.tecmint.com/enable-rpmforge-repository/
When tring to install Sybase I got the below error `nothing to do`
the results from running `yum repolist -v` are below
[root@9-srv-nagios downloads]# yum search perl | grep Sybase
[root@9-srv-nagios downloads]# yum install perl-DBD-Sybase Loaded plugins: fastestmirror
* base: mirror.as29550.net
* extras: mirror.simwood.com
* rpmforge: www.mirrorservice.org
[root@9-srv-nagios downloads]# yum repolist -v
Loading "fastestmirror" plugin
Config time: 0.008
Yum version: 3.4.3
Setting up Package Sacks
pkgsack time: 0.008
Repo-id : base/7/x86_64
Repo-name : CentOS-7 - Base
Repo-revision: 1427842153
Repo-updated : Tue Mar 31 23:50:46 2015
Repo-pkgs : 8,652
Repo-size : 6.3 G
Repo-mirrors : http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=os&infra=stock
Repo-baseurl : http://mirror.as29550.net/mirror.centos.org/7.1.1503/os/x86_64/
: (9 more)
Repo-expire : 21,600 second(s) (last: Wed Jun 17 09:08:24 2015)
Repo-filename: /etc/yum.repos.d/CentOS-Base.repo
Repo-id : epel/x86_64
Repo-name : Extra Packages for Enterprise Linux 7 - x86_64
Repo-revision: 1434217867
Repo-tags : binary-x86_64
Repo-updated : Sat Jun 13 18:53:13 2015
Repo-pkgs : 8,076
Repo-size : 5.6 G
Repo-metalink: https://mirrors.fedoraproject.org/metalink?repo=epel-7&arch=x86_64
Updated : Sat Jun 13 18:53:13 2015
Repo-baseurl : http://www.mirrorservice.org/sites/dl.fedoraproject.org/pub/epel/7/x86_64/
: (67 more)
Repo-expire : 21,600 second(s) (last: Wed Jun 17 09:08:37 2015)
Repo-filename: /etc/yum.repos.d/epel.repo
Repo-id : extras/7/x86_64
Repo-name : CentOS-7 - Extras
Repo-revision: 1432315092
Repo-updated : Fri May 22 18:19:02 2015
Repo-pkgs : 128
Repo-size : 464 M
Repo-mirrors : http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=extras&infra=stock
Repo-baseurl : http://mirror.simwood.com/centos/7.1.1503/extras/x86_64/ (9 more)
Repo-expire : 21,600 second(s) (last: Wed Jun 17 09:08:38 2015)
Repo-id : rpmforge
Repo-name : RHEL 7 - RPMforge.net - dag
Repo-updated : Fri Jul 11 02:46:42 2014
Repo-pkgs : 245
Repo-size : 198 M
Repo-baseurl : http://apt.sw.be/redhat/el7/en/x86_64/rpmforge/
Repo-mirrors : http://mirrorlist.repoforge.org/el7/mirrors-rpmforge
Repo-expire : 21,600 second(s) (last: Wed Jun 17 09:08:45 2015)
Repo-filename: /etc/yum.repos.d/rpmforge.repo
Repo-id : updates/7/x86_64
Repo-name : CentOS-7 - Updates
Repo-revision: 1434398283
Repo-updated : Mon Jun 15 20:58:42 2015
Repo-pkgs : 673
Repo-size : 1.8 G
Repo-mirrors : http://mirrorlist.centos.org/?release=7&arch=x86_64&repo=updates&infra=stock
Repo-baseurl : http://mirror.as29550.net/mirror.centos.org/7.1.1503/updates/x86_64/
: (9 more)
Repo-expire : 21,600 second(s) (last: Wed Jun 17 09:08:46 2015)
repolist: 17,774
Thanks for the help, I've resolved the issue.
I rolled back the VM to a time before I attempted to configure the check_mssql_health plugin, I added the nagios user to the suders file and then installed/configured the plugin and prerequisites as nagios using the sudo command.
Thanks again.
Thanks again.
Sounds good(ie)! I'll be closing this thread now, but feel free to open another if you need anything in the future!
