Services don't warn on stop/waiting
Re: Services don't warn on stop/waiting
You forgot to run:
echo $?
after each command... I wanted to see the exit codes from each command. Otherwise, the output looks fine.
Can you also run the following command on the remote machine and show us the output?
grep check_init_service /etc/sudoers
If you are missing the line below:
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_service
you may add it to sudoers to see if this is going to fix the issue.
courhar
Post by courhar »
Done both of those. Should the exit code be a 1 rather than 0 then?
jolson
Attack Rabbit
Post by jolson »
You are correct - the exit codes are specified as follows:
0 OK UP
1 WARNING UP or DOWN/UNREACHABLE*
2 CRITICAL DOWN/UNREACHABLE
3 UNKNOWN DOWN/UNREACHABLE
Twits Blog
courhar
Post by courhar »
So how can I change the check_init_services script so that it gives a 1? for finding a service stopped/waiting? or even a 2 as the services are critical for what we are trying to monitor.
Is the service actually running? Can you run the following command on the remote machine and show us the output?
ps aux | grep heat-api
If the "check_init_service" is not working with this service, perhaps you can find a different plugin or set up a custom command in order to accomplish your goal.
courhar
Post by courhar »
Ran the command you asked. Is there another plug in you could recommend? I tried check_services which didn't alarm either.
Courhar
You may want to try using SNMP. Please, review our documentation on the topic here:
https://assets.nagios.com/downloads/nag ... g_SNMP.pdf
An example of a command for checking the sshd process would be:
/usr/local/nagios/libexec/check_snmp_process_wizard.pl -H <remote machine>  -C <community string> --v2c -n 'sshd' -w '1,30' -c '1,50'
2 process matching sshd (> 1) (<= 30):OK
I am not sure if using "heat-api" as the name of the process (regexp) will produce the expected results. You may need to run snmpwalk to see what is available.
