Service checks notifications swithcing back to enabled
Re: Service checks notifications swithcing back to enabled
You can delete or modify the retention.dat, regardless of what it says on the top of the file, but you must stop nagios prior to doing so. I would not recommend deleting it as this will set all of your checks to pending state, and you will lose the downtime and comment info. Read more about the retention.dat here:
http://nagios.sourceforge.net/docs/nagi ... ntion_file
You can however, remove/modify one entry (i.e. host/service config) - it should get recreate it after you start the nagios service. If you want to delete the file, you could run:
service nagios stop
rm -f /usr/local/nagios/var/retention.dat
service nagios start
krobertson71
Post by krobertson71 »
I checked retention.dat and all seems well. I then checked a particular host where in the GUI it is showing notifications disabled:
Here is the code segments from status.dat and retention.dat. They both show notifications disabled for the particular service, but CCM still shows them "ON". This is even after I restarted Nagios. So having trouble making sense of this.
Status.dat
servicestatus {
        host_name=hostname1
        service_description=Swap Usage
        modified_attributes=1
        check_command=check_xi_ncpa_agent!-t 'mytoken' -P 5693 -M memory/swap/percent -w 85 -c 90!!!!!!!
        check_period=xi_timeperiod_24x7
        notification_period=xi_timeperiod_24x7
        check_interval=15.000000
        retry_interval=1.000000
        event_handler=
        has_been_checked=1
        should_be_scheduled=1
        check_execution_time=0.111
        check_latency=0.000
        check_type=0
        current_state=0
        last_hard_state=0
        last_event_id=148683
        current_event_id=151368
        current_problem_id=0
        last_problem_id=67078
        current_attempt=1
        max_attempts=5
        state_type=1
        last_state_change=1432852487
        last_hard_state_change=1432852487
        last_time_ok=1434465527
        last_time_warning=0
        last_time_unknown=1432852487
        last_time_critical=0
        plugin_output=OK: percent was 0%
        long_plugin_output=
        performance_data='percent_0'=0%;85;90;
        last_check=1434465527
        next_check=1434466427
        check_options=0
        current_notification_number=0
        current_notification_id=91293
        last_notification=0
        next_notification=0
        no_more_notifications=0
        [b][u]notifications_enabled=0[/u][/b]
        active_checks_enabled=1
        passive_checks_enabled=1
        event_handler_enabled=1
Retention.dat
service {
host_name=hostname1
event_handler=
has_been_checked=1
check_latency=0.000
check_type=0
current_state=0
last_state=0
last_hard_state=0
current_attempt=1
max_attempts=5
normal_check_interval=15.000000
retry_check_interval=1.000000
state_type=1
last_time_warning=0
long_plugin_output=
check_options=0
notified_on_unknown=0
notified_on_warning=0
notified_on_critical=0
last_notification=0
problem_has_been_acknowledged=0
But as you can see CCM, even after a Nagios restart, still shows notifications for this service check as on.
Also found this in the objects.cache.. as you can see here notifications are enabled, where they are not in status.dat and retention.dat, even after a restart.
        host_name       arlgasp01.dcri.duke.net
        service_description     Swap Usage
        check_period    xi_timeperiod_24x7
        check_command   check_xi_ncpa_agent!-t 'mytoken' -P 5693 -M memory/swap/percent -w 85 -c 90!!!!!!!
        contact_groups  Linux Team
        notification_period     xi_timeperiod_24x7
        initial_state   o
        importance      0
        check_interval  15.000000
        retry_interval  1.000000
        max_check_attempts      5
        is_volatile     0
        parallelize_check       1
        active_checks_enabled   1
        passive_checks_enabled  1
        obsess  1
        event_handler_enabled   1
        low_flap_threshold      0.000000
        high_flap_threshold     0.000000
        flap_detection_enabled  1
        flap_detection_options  a
        freshness_threshold     0
        check_freshness 0
        notification_options    a
        notifications_enabled   1
        notification_interval   360.000000
        first_notification_delay        0.000000
        stalking_options        n
        process_perf_data       1
        retain_status_information       1
        retain_nonstatus_information    1
        _XIWIZARD       ncpa
abrist
Red Shirt
Post by abrist »
If you enable notifications for object, and then restart nagios, does the setting stick? (check retention.dat)
You could also stop nagios and then change the notifications_enabled directive and then restart Nagios.
