No perfdata.log
ss6396
Re: No perfdata.log
Post by ss6396 »
Files attached.
Re: No perfdata.log
In the process_perfdata.cfg file, some of the settings have 3 / in them, you should edit that file and change them to only one /.
Can you run the following and post the output here?
ls -lR /opt/app/nagios/var/
ss6396
Re: No perfdata.log
Post by ss6396 »
We noticed the triple / thing to and have tried removing the extra /'s, no change. Besides, we do have other installations with those triple /'s and performance data is working as expected.
Output from:
$ ls -lR /opt/app/nagios/var/
/opt/app/nagios/var/:
total 448
drwxrwxr-x 2 nagios nagios 4096 Jun 21 23:59 archives
-rw-r--r-- 1 nagios nagios 209 Jun 22 16:51 host-perfdata
-rw-r--r-- 1 nagios nagios 7 Jun 22 10:37 nagios.lock
-rw-r--r-- 1 nagios nagios 44523 Jun 22 16:45 nagios.log
-rw-r--r-- 1 nagios nagios 7 Jun 22 10:37 ndo2db.lock
-rw-r--r-- 1 nagios nagios 0 Jun 18 09:53 ndomod.tmp
srwxr-xr-x 1 nagios nagios 0 Jun 22 10:37 ndo.sock
-rw-r--r-- 1 nagios nagios 551 Jun 22 10:37 npcd.log
-rw-r--r-- 1 nagios nagios 6 Jun 22 10:37 npcd.pid
-rw-r--r-- 1 nagios nagios 7 Jun 22 10:36 nrpe.pid
-rw-r--r-- 1 nagios nagios 7 Jun 22 10:40 nsca.pid
-rw-r--r-- 1 nagios nagios 99468 Jun 22 10:37 objects.cache
-rw------- 1 nagios nagios 124670 Jun 22 16:37 retention.dat
drwxrwsr-x 2 nagios apache 4096 Jun 22 10:37 rw
-rw-r--r-- 1 nagios nagios 1803 Jun 22 16:51 service-perfdata
drwxrwsr-x 5 nagios apache 4096 Jun 17 14:55 spool
drwxrwxr-x 2 nagios nagios 4096 Jun 22 16:51 stats
-rw-rw-r-- 1 nagios nagios 124481 Jun 22 16:51 status.dat
drwxrwxr-x 2 nagios nagios 4096 Jun 17 14:49 tmp
/opt/app/nagios/var/archives:
total 340
-rw-r--r-- 1 nagios nagios 78524 Jun 18 09:41 nagios-06-18-2015-00.log
-rw-r--r-- 1 nagios nagios 73711 Jun 22 10:35 nagios-06-19-2015-00.log
-rw-r--r-- 1 nagios nagios 55760 Jun 19 23:53 nagios-06-20-2015-00.log
-rw-r--r-- 1 nagios nagios 55553 Jun 20 23:53 nagios-06-21-2015-00.log
-rw-r--r-- 1 nagios nagios 54490 Jun 21 23:53 nagios-06-22-2015-00.log
/opt/app/nagios/var/rw:
total 0
prw-rw---- 1 nagios apache 0 Jun 17 14:45 nagios.cmd
srw-rw---- 1 nagios apache 0 Jun 22 10:37 nagios.qh
/opt/app/nagios/var/spool:
total 12
drwxrwsr-x 2 nagios apache 4096 Jun 22 16:51 checkresults
drwxrwxrwx 2 nagios nagios 4096 Jun 22 16:51 perfdata
drwxrwxr-x 2 nagios nagios 4096 Jun 22 16:51 xidpe
/opt/app/nagios/var/spool/checkresults:
total 12
-rwxrwx--- 1 apache apache 239 Jun 22 16:51 cgQQeev
-rw-r----- 1 apache apache 0 Jun 22 16:51 cgQQeev.ok
-rwxrwx--- 1 apache apache 251 Jun 22 16:51 cNm7Q8D
-rw-r----- 1 apache apache 0 Jun 22 16:51 cNm7Q8D.ok
-rwxrwx--- 1 apache apache 257 Jun 22 16:51 cq2iR4w
-rw-r----- 1 apache apache 0 Jun 22 16:51 cq2iR4w.ok
/opt/app/nagios/var/spool/perfdata:
total 8
-rw-r--r-- 1 nagios nagios 0 Jun 22 16:51 1435006300.perfdata.host
-rw-r--r-- 1 nagios nagios 4898 Jun 22 16:51 1435006300.perfdata.service
/opt/app/nagios/var/spool/xidpe:
total 0
/opt/app/nagios/var/stats:
total 4
-rw-rw-r-- 1 nagios nagios 195 Jun 22 16:51 23916771
/opt/app/nagios/var/tmp:
total 0
Re: No perfdata.log
Couple of more commands to run.
ll /opt/app/nagios/share/
ls -lR /opt/app/nagios/share/perfdata
ss6396
Re: No perfdata.log
Post by ss6396 »
$ ll /opt/app/nagios/share/
total 104
drwxr-xr-x 2 root nagios 4096 Jun 17 14:52 ajaxterm
-rwxrwxr-x 1 nagios nagios 568 Jun 17 14:47 config.inc.php
drwxrwxr-x 2 nagios nagios 4096 Jun 17 14:47 contexthelp
drwxrwxr-x 3 nagios nagios 4096 Jun 17 14:45 docs
drwxrwxr-x 3 nagios nagios 4096 Jun 17 14:45 images
drwxrwxr-x 3 nagios nagios 4096 Jun 17 14:47 includes
-rwxrwxr-x 1 nagios nagios 1628 Jun 17 14:47 index.php
drwxrwxr-x 2 nagios nagios 4096 Jun 17 14:47 js
-rwxrwxr-x 1 nagios nagios 1176 Jun 17 14:47 jsonquery.html
drwxrwxr-x 4 nagios nagios 4096 Jun 17 14:46 locale
-rwxrwxr-x 1 nagios nagios 8697 Jun 17 14:47 main.php
drwxrwxr-x 2 nagios nagios 4096 Jun 17 14:45 media
drwxrwxr-x 9 nagios nagios 4096 Jun 17 17:21 perfdata
drwxrwxr-x 8 nagios nagios 4096 Jun 17 14:49 pnp
-rwxrwxr-x 1 nagios nagios 26 Jun 17 14:47 robots.txt
-rwxrwxr-x 1 nagios nagios 656 Jun 17 14:47 rss-corebanner.php
-rwxrwxr-x 1 nagios nagios 1064 Jun 17 14:47 rss-corefeed.html
-rwxrwxr-x 1 nagios nagios 895 Jun 17 14:47 rss-corefeed.php
-rwxrwxr-x 1 nagios nagios 540 Jun 17 14:47 rss-newsfeed.html
-rwxrwxr-x 1 nagios nagios 1064 Jun 17 14:47 rss-newsfeed.php
-rwxrwxr-x 1 nagios nagios 6009 Jun 17 14:47 side.php
drwxrwxr-x 2 nagios nagios 4096 Jun 17 14:45 ssi
drwxrwxr-x 2 nagios nagios 4096 Jun 17 14:47 stylesheets
$ ls -lR /opt/app/nagios/share/perfdata
/opt/app/nagios/share/perfdata:
total 24
drwxrwxr-x 2 nagios nagios 4096 Jun 23 08:39 135.110.216.43
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:37 cafrfd1patrla02.itservices.sbc.com
drwxrwxr-x 2 nagios nagios 4096 Jun 23 08:38 localhost
drwxrwxr-x 2 nagios nagios 4096 Jun 23 08:39 patinfra.sldc.sbc.com
drwxrwxr-x 2 nagios nagios 4096 Jun 23 08:36 zlp07622.vci.att.com
drwxrwxr-x 2 nagios nagios 4096 Jun 23 08:38 zlpv2522.vci.att.com
/opt/app/nagios/share/perfdata/135.110.216.43:
total 24
-rw-rw-r-- 1 nagios nagios 2125 Jun 23 08:39 Filespace_boot.xml
-rw-rw-r-- 1 nagios nagios 2125 Jun 23 08:39 Filespace_home.xml
-rw-rw-r-- 1 nagios nagios 2125 Jun 23 08:39 Filespace_root.xml
-rw-rw-r-- 1 nagios nagios 2119 Jun 23 08:39 Filespace_tmp.xml
-rw-rw-r-- 1 nagios nagios 2119 Jun 23 08:39 Filespace_usr.xml
-rw-rw-r-- 1 nagios nagios 2119 Jun 23 08:39 Filespace_var.xml
/opt/app/nagios/share/perfdata/cafrfd1patrla02.itservices.sbc.com:
total 8
-rwxrwxr-x 1 nagios nagios 2211 Jun 18 18:37 NT-DiskSpace_C.xml
-rwxrwxr-x 1 nagios nagios 2187 Jun 18 18:37 NT-DiskSpace_D.xml
/opt/app/nagios/share/perfdata/localhost:
total 32
-rw-rw-r-- 1 nagios nagios 3485 Jun 23 08:35 Current_Load.xml
-rw-rw-r-- 1 nagios nagios 2044 Jun 23 08:38 Current_Users.xml
-rw-rw-r-- 1 nagios nagios 3874 Jun 23 08:38 _HOST_.xml
-rw-rw-r-- 1 nagios nagios 2722 Jun 23 08:36 PING.xml
-rw-rw-r-- 1 nagios nagios 2087 Jun 23 08:38 Root_Partition.xml
-rw-rw-r-- 1 nagios nagios 2003 Jun 23 08:36 SSH.xml
-rw-rw-r-- 1 nagios nagios 2056 Jun 23 08:37 Swap_Usage.xml
-rw-rw-r-- 1 nagios nagios 2090 Jun 23 08:37 Total_Processes.xml
/opt/app/nagios/share/perfdata/patinfra.sldc.sbc.com:
total 72
-rw-rw-r-- 1 nagios nagios 2068 Jun 23 08:39 CPULoad.xml
-rw-rw-r-- 1 nagios nagios 2131 Jun 23 08:39 Filespace_bto-appl.xml
-rw-rw-r-- 1 nagios nagios 2125 Jun 23 08:39 Filespace_bto-sys.xml
-rw-rw-r-- 1 nagios nagios 2101 Jun 23 00:59 Filespace_bto.xml
-rw-rw-r-- 1 nagios nagios 2153 Jun 23 08:39 Filespace_export-home.xml
-rw-rw-r-- 1 nagios nagios 2111 Jun 23 08:39 Filespace_home.xml
-rw-rw-r-- 1 nagios nagios 2101 Jun 23 08:39 Filespace_opt.xml
-rw-rw-r-- 1 nagios nagios 2107 Jun 23 08:39 Filespace_root.xml
-rw-rw-r-- 1 nagios nagios 2100 Jun 23 08:39 Filespace_tmp.xml
-rw-rw-r-- 1 nagios nagios 2149 Jun 23 08:39 Filespace_usr-localcw.xml
-rw-rw-r-- 1 nagios nagios 2137 Jun 23 08:39 Filespace_usr-local.xml
-rw-rw-r-- 1 nagios nagios 2101 Jun 23 08:39 Filespace_usr.xml
-rw-rw-r-- 1 nagios nagios 2161 Jun 23 08:39 Filespace_var-adm-crash.xml
-rw-rw-r-- 1 nagios nagios 2143 Jun 23 08:39 Filespace_var-adm-sa.xml
-rw-rw-r-- 1 nagios nagios 2125 Jun 23 08:39 Filespace_var-adm.xml
-rw-rw-r-- 1 nagios nagios 2137 Jun 23 08:39 Filespace_var-crash.xml
-rw-rw-r-- 1 nagios nagios 2149 Jun 23 08:39 Filespace_var-VRTSvcs.xml
-rw-rw-r-- 1 nagios nagios 2101 Jun 23 08:39 Filespace_var.xml
/opt/app/nagios/share/perfdata/zlp07622.vci.att.com:
total 4
-rw-rw-r-- 1 nagios nagios 2760 Jun 23 08:36 HTTP.xml
/opt/app/nagios/share/perfdata/zlpv2522.vci.att.com:
total 52
-rw-rw-r-- 1 nagios nagios 2062 Jun 23 08:38 CPULoad.xml
-rw-rw-r-- 1 nagios nagios 2105 Jun 23 08:38 Filespace_boot.xml
-rw-rw-r-- 1 nagios nagios 2101 Jun 23 08:38 Filespace_home.xml
-rw-rw-r-- 1 nagios nagios 2097 Jun 23 08:38 Filespace_root.xml
-rw-rw-r-- 1 nagios nagios 2094 Jun 23 08:38 Filespace_tmp.xml
-rw-rw-r-- 1 nagios nagios 2146 Jun 23 08:38 Filespace_usr-localcw.xml
-rw-rw-r-- 1 nagios nagios 2134 Jun 23 08:38 Filespace_usr-local.xml
-rw-rw-r-- 1 nagios nagios 2098 Jun 23 08:38 Filespace_usr.xml
-rw-rw-r-- 1 nagios nagios 2154 Jun 23 08:38 Filespace_var-adm-crash.xml
-rw-rw-r-- 1 nagios nagios 2118 Jun 23 08:38 Filespace_var-adm.xml
-rw-rw-r-- 1 nagios nagios 2118 Jun 23 08:38 Filespace_var-tmp.xml
-rw-rw-r-- 1 nagios nagios 2142 Jun 23 08:38 Filespace_var-VRTSvcs.xml
-rw-rw-r-- 1 nagios nagios 2094 Jun 23 08:38 Filespace_var.xml
Re: No perfdata.log
Could you upload these files?
/opt/app/nagios/etc/pnp/npcd.cfg
/opt/app/nagios/etc/commands.cfg
/opt/app/nagios/share/perfdata/localhost/PING.xml
ss6396
Re: No perfdata.log
Post by ss6396 »
Requested files attached.
Re: No perfdata.log
ps -ef|grep npcd
ss6396 106906 105377 0 13:27 pts/0 00:00:00 grep npcd
nagios 130153 1 0 Jun17 ? 00:00:18 //opt/app/nagios/bin/npcd -f /
Is the output "cut off"? I don't see the config file... Can you try killing npcd and start it by running in the CLI the following command?
/opt/app/nagios/bin/npcd -f /path/to/the/npcd.cfg -d
Does this help?
ss6396
Re: No perfdata.log
Post by ss6396 »
I guess the output of the ps command was cut off, here is the complete output:
ZLP07622:nagios: ps -ef|grep npcd
nagios 112606 110030 0 12:13 pts/1 00:00:00 grep npcd
nagios 117882 1 0 Jun22 ? 00:00:10 //opt/app/nagios/bin/npcd -f //opt/app/nagios/etc/pnp/npcd.cfg -d
Stopping and restarting the npcd daemon does not help.
Re: No perfdata.log
OK, run the following commands and show us the output:
which rrdtool
whereis rrdtool
ll /opt/app/nagios/libexec/process_perfdata.pl
ps -ef | grep cron
cat /etc/cron.d/nagiosxi
