juil. 10 16:55:46 soaserver su[12420]: (to nagios) root on none
juil. 10 16:55:46 soaserver systemd[1]: Starting Session c14 of user nagios.
juil. 10 16:55:46 soaserver systemd[1]: Started Session c14 of user nagios.
juil. 10 16:55:46 soaserver su[12420]: pam_unix(su-l:session): session opened for user nagios by (uid=0)
juil. 10 16:55:46 soaserver su[12420]: pam_unix(su-l:session): session closed for user nagios
juil. 10 16:55:46 soaserver nagios[12418]: Starting nagios:
juil. 10 16:55:46 soaserver nagios[12418]: Nagios Core 4.0.4
juil. 10 16:55:46 soaserver nagios[12418]: Copyright (c) 2009-present Nagios Core Development Team and Community Contributors
juil. 10 16:55:46 soaserver nagios[12418]: Copyright (c) 1999-2009 Ethan Galstad
juil. 10 16:55:46 soaserver nagios[12418]: Last Modified: 03-14-2014
juil. 10 16:55:46 soaserver nagios[12418]: License: GPL
juil. 10 16:55:46 soaserver nagios[12418]: Website: http://www.nagios.org
juil. 10 16:55:46 soaserver nagios[12418]: Reading configuration data...
juil. 10 16:55:46 soaserver nagios[12418]: Read main config file okay...
juil. 10 16:55:46 soaserver nagios[12418]: Error: Could not find any host matching 'srv64' (config file '/usr/local/nagios/etc/objects/services.cfg', starting on line 10)
juil. 10 16:55:46 soaserver nagios[12418]: Error: Failed to expand host list 'srv64' for service 'Memory' (/usr/local/nagios/etc/objects/services.cfg:10)
juil. 10 16:55:46 soaserver nagios[12418]: Error processing object config files!
juil. 10 16:55:46 soaserver nagios[12418]: ***> One or more problems was encountered while processing the config files...
juil. 10 16:55:46 soaserver nagios[12418]: Check your configuration file(s) to ensure that they contain valid
juil. 10 16:55:46 soaserver nagios[12418]: directives and data defintions. If you are upgrading from a previous
juil. 10 16:55:46 soaserver nagios[12418]: version of Nagios, you should be aware that some variables/definitions
juil. 10 16:55:46 soaserver nagios[12418]: may have been removed or modified in this version. Make sure to read
juil. 10 16:55:46 soaserver nagios[12418]: the HTML documentation regarding the config files, as well as the
juil. 10 16:55:46 soaserver nagios[12418]: 'Whats New' section to find out what has changed.
juil. 10 16:55:46 soaserver systemd[1]: nagios.service: control process exited, code=exited status=8
juil. 10 16:55:46 soaserver systemd[1]: Unit nagios.service entered failed state.
juil. 10 16:56:11 soaserver su[12740]: (to nagios) root on none
juil. 10 16:56:11 soaserver systemd[1]: Starting Session c15 of user nagios.
juil. 10 16:56:11 soaserver systemd[1]: Started Session c15 of user nagios.
juil. 10 16:56:12 soaserver su[12740]: pam_unix(su-l:session): session opened for user nagios by (uid=0)
juil. 10 16:56:12 soaserver su[12740]: pam_unix(su-l:session): session closed for user nagios
juil. 10 16:56:12 soaserver nagios[12738]: Starting nagios:
juil. 10 16:56:12 soaserver nagios[12738]: Nagios Core 4.0.4
juil. 10 16:56:12 soaserver nagios[12738]: Copyright (c) 2009-present Nagios Core Development Team and Community Contributors
juil. 10 16:56:12 soaserver nagios[12738]: Copyright (c) 1999-2009 Ethan Galstad
juil. 10 16:56:12 soaserver nagios[12738]: Last Modified: 03-14-2014
juil. 10 16:56:12 soaserver nagios[12738]: License: GPL
juil. 10 16:56:12 soaserver nagios[12738]: Website: http://www.nagios.org
juil. 10 16:56:12 soaserver nagios[12738]: Reading configuration data...
juil. 10 16:56:12 soaserver nagios[12738]: Read main config file okay...
juil. 10 16:56:12 soaserver nagios[12738]: Error: Could not find any host matching 'srv64' (config file '/usr/local/nagios/etc/objects/services.cfg', starting on line 10)
juil. 10 16:56:12 soaserver nagios[12738]: Error: Failed to expand host list 'srv64' for service 'Memory' (/usr/local/nagios/etc/objects/services.cfg:10)
juil. 10 16:56:12 soaserver nagios[12738]: Error processing object config files!
juil. 10 16:56:12 soaserver nagios[12738]: ***> One or more problems was encountered while processing the config files...
juil. 10 16:56:12 soaserver nagios[12738]: Check your configuration file(s) to ensure that they contain valid
juil. 10 16:56:12 soaserver nagios[12738]: directives and data defintions. If you are upgrading from a previous
juil. 10 16:56:12 soaserver nagios[12738]: version of Nagios, you should be aware that some variables/definitions
juil. 10 16:56:12 soaserver nagios[12738]: may have been removed or modified in this version. Make sure to read
juil. 10 16:56:12 soaserver nagios[12738]: the HTML documentation regarding the config files, as well as the
juil. 10 16:56:12 soaserver nagios[12738]: 'Whats New' section to find out what has changed.
juil. 10 16:56:12 soaserver systemd[1]: nagios.service: control process exited, code=exited status=8
juil. 10 16:56:12 soaserver systemd[1]: Unit nagios.service entered failed state.
where is hosts.cfg and service.cfg
Re: where is hosts.cfg and service.cfg
Nagios Core 4.0.4
License: GPL
Error: Could not find any host matching 'srv64.firstheberg.net' (config file '/usr/local/nagios/etc/objects/services.cfg', starting on line 10)
Error: Failed to expand host list 'srv64.firstheberg.net' for service 'Memory' (/usr/local/nagios/etc/objects/services.cfg:10)
License: GPL
jdalrymple
- Skynet Drone
It doesn't get any clearer. You have a service assigned to a host that doesn't exist.sbacarach wrote:juil. 10 16:56:12 soaserver nagios[12738]: Error: Could not find any host matching 'srv64' (config file '/usr/local/nagios/etc/objects/services.cfg', starting on line 10)
Oki thanks for your help i see my problem.
The hosts.cfg file is very bad !
thanks a lot
thanks a lot
Let us know what you find out. Thanks!
