Multiple IP Address per Host Strategies
jdalrymple
Skynet Drone
Re: Multiple IP Address per Host Strategies
Post by jdalrymple »
wltjr wrote:dealing with multiple IPs per host and strategies there
wltjr wrote:the main issue was and still is having MULTIPLE IP addresses per host and passing those on. I have gone with #4 and implemented custom host macros
What did you do with those host macros? I mean at this point I guess it sounds like your problem is resolved so I guess it doesn't really matter. I just feel like all along I've totally misunderstood the actual problem and maybe if I knew why you cared to store those addresses in macros I'd perhaps understand what you were trying to do that I was totally misunderstanding.
wltjr wrote:Just seems bit hackish and not so elegant, but works.
$HOSTADDRESS$ is a construct indicating how Nagios is intended to communicate with the monitored device, nothing else. It sounds like you needed a different sort of macro for a different reason. All that said, hackish and not so elegant is often the only answer, and who cares if it works?
