nrds stopped working after its first check
Re: nrds stopped working after its first check
Okay. It appears to be working. 1 check so far. Nothing bad in the log. I think that the service name was the issue. And originally I believe I may have put in "nrpe_diskspace B" and "nrpe_diskspace D" This time I used _ instead of a space. The log seems happy and I have data in the graphing. The one thing I'm worried about is that I had to have those entries in config manager before I installed nrds.exe and that putting it in after the fact caused it to stop. But since I'm pretty sure it was the naming of the service that was the issue, I'm confident that doing after the fact and letting it go through the update of the config it may work now. It is worth a try to check. Maybe later. It's nice that I think it's working. I'll let it run over night and repost results. Thanks for the assistance.
Sounds good! We will keep the thread open for the time being awaiting your feedback.I'll let it run over night and repost results.
