SNMP Trap Sender
Re: SNMP Trap Sender
Ok, I noticed from your screenshot that your tcpdump is listening on eth9, is that the proper one?
Have you checked on the destination server at all?
yes, is correct. If I run snmptrap from command line with nagios user trap is sent even though there are errors about snmpapp.conf.
[nagios@az84mon11v ~]$ /usr/bin/snmptrap -v 2c -c public 10.48.0.33:1162 '' NAGIOS-NOTIFY-MIB::nSvcEvent nSvcHostname s "MYHOST" nSvcDesc s "THISSERVICE" nSvcStateID i 1 nSvcOutput s "HELLO WORLD"
No log handling enabled - turning on stderr logging
Cannot rename /var/lib/net-snmp/snmpapp.conf to /var/lib/net-snmp/snmpapp.0.conf
Cannot unlink /var/lib/net-snmp/snmpapp.conf
read_config_store open failure on /var/lib/net-snmp/snmpapp.conf
read_config_store open failure on /var/lib/net-snmp/snmpapp.confCode: Select all
[root@az84mon11v ~]# tcpdump udp dst port 1162
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth9, link-type EN10MB (Ethernet), capture size 65535 bytes
12:04:42.316952 IP az84mon11v.am.freescale.net.35528 > AZ84SOFTEVAL01C.am.freescale.net.health-trap: UDP, length 177- Box293
- Too Basu
I ran your test and did not get those errors.
What are the permissions on the file?
ls -al /var/lib/net-snmp/snmpapp.confAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Here are the permissions.
[root@az84mon11v ~]# ls -al /var/lib/net-snmp/snmpapp.conf
-rw------- 1 root root 675 Jul 17 12:22 /var/lib/net-snmp/snmpapp.confRe: SNMP Trap Sender
I get the same errors when running the snmptrap command as the nagios user and mine works properly. Let me dig into the code to see if we have any additional logging we can look at.
Post the full output of this command:
You may want to try downloading the snmptrapsender component again:
https://assets.nagios.com/downloads/nag ... sender.zip
Then go to Admin > Manage Components and re-upload the component so that it re-installs and try it again.
echo "select value from xi_options where name = 'snmptrapsender_component_options';" | psql nagiosxi nagiosxihttps://assets.nagios.com/downloads/nag ... sender.zip
