This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
snapon_admin
Posts: 952 Joined: Mon Jun 10, 2013 10:39 am
Post
by snapon_admin » Wed Jul 29, 2015 9:58 am
ssax wrote: What does your /var/log/messages show for that trap? It doesn't look like it's including that var.
This is everything in /var/log/messages concerning the trap at 14:03 yesterday:
Jul 28 14:03:01 lisl-ngos-01-pv snmptrapd[16929]: 2015-07-28 14:03:01 <UNKNOWN> [UDP: [<IP ADDRESS>]:9896->[<IP ADDRESS>]]:#012.1.3.6.1.2.1.1.3.0 = Timeticks: (131028291) 15 days, 3:58:02.91#011.1.3.6.1.6.3.1.1.4.1.0 = OID: .1.3.6.1.4.1.111.15.2#011.1.3.6.1.4.1.111.15.3.1.1.2.1 = STRING: "NOTIF_NORMAL"#011.1.3.6.1.4.1.111.15.3.1.1.3.1 = STRING: "Failed to connect to database instance: Failed to connect: java.sql.SQLException: The Network Adapter could not establish the connection."#011.1.3.6.1.4.1.111.15.3.1.1.4.1 = STRING: "https://lisgrid01p.snapon.com:7799/em/redirect?pageType=sdk-core-event-console-detailEvent&issueID=1AC3FC17957527C9E054020820F4DF2F"#011.1.3.6.1.4.1.111.15.3.1.1.5.1 = STRING: "Fatal"#011.1.3.6.1.4.1.111.15.3.1.1.6.1 = STRING: "FATAL"#011.1.3.6.1.4.1.111.15.3.1.1.7.1 = STRING: "0"#011.1.3.6.1.4.1.111.15.3.1.1.8.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.9.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.10.1 = STRING: "Jul 28, 2015 2:03:00 PM CDT"#011.1.3.6.1.4.1.111.15.3.1.1.11.1 = STRING: "Availability"#011.1.3.6.1.4.1.111.15.3.1.1.12.1 = STRING: "Availability"#011.1.3.6.1.4.1.111.15.3.1.1.13.1 = STRING: "Target Availability"#011.1.3.6.1.4.1.111.15.3.1.1.14.1 = STRING: "Status"#011.1.3.6.1.4.1.111.15.3.1.1.15.1 = STRING: "264"#011.1.3.6.1.4.1.111.15.3.1.1.16.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.17.1 = STRING: "No"#011.1.3.6.1.4.1.111.15.3.1.1.18.1 = STRING: "New"#011.1.3.6.1.4.1.111.15.3.1.1.19.1 = STRING: "None"#011.1.3.6.1.4.1.111.15.3.1.1.20.1 = STRING: "0"#011.1.3.6.1.4.1.111.15.3.1.1.21.1 = STRING: "kdblab01.snapon.com"#011.1.3.6.1.4.1.111.15.3.1.1.22.1 = STRING: "https://lisgrid01p.snapon.com:7799/em/redirect?pageType=TARGET_HOMEPAGE&targetName=kdblab01.snapon.com&targetType=oracle_database"#011.1.3.6.1.4.1.111.15.3.1.1.23.1 = STRING: "Database Instance"#011.1.3.6.1.4.1.111.15.3.1.1.24.1 = STRING: "kenrman01t.snapon.com"#011.1.3.6.1.4.1.111.15.3.1.1.25.1 = STRING: "SYSMAN"#011.1.3.6.1.4.1.111.15.3.1.1.26.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.27.1 = STRING: "11.2.0.3.0"#011.1.3.6.1.4.1.111.15.3.1.1.28.1 = STRING: "
Jul 28 14:03:02 lisl-ngos-01-pv snmptrapd[16929]: 2015-07-28 14:03:02 <UNKNOWN> [UDP: [<IP ADDRESS>]:9896->[<IP ADDRESS>]]:#012.1.3.6.1.2.1.1.3.0 = Timeticks: (131028318) 15 days, 3:58:03.18#011.1.3.6.1.6.3.1.1.4.1.0 = OID: .1.3.6.1.4.1.111.15.2#011.1.3.6.1.4.1.111.15.3.1.1.2.1 = STRING: "NOTIF_NORMAL"#011.1.3.6.1.4.1.111.15.3.1.1.3.1 = STRING: "The database status is UNKNOWN."#011.1.3.6.1.4.1.111.15.3.1.1.4.1 = STRING: "https://lisgrid01p.snapon.com:7799/em/redirect?pageType=sdk-core-event-console-detailEvent&issueID=1AC3FC17956F27C9E054020820F4DF2F"#011.1.3.6.1.4.1.111.15.3.1.1.5.1 = STRING: "Critical"#011.1.3.6.1.4.1.111.15.3.1.1.6.1 = STRING: "CRITICAL"#011.1.3.6.1.4.1.111.15.3.1.1.7.1 = STRING: "0"#011.1.3.6.1.4.1.111.15.3.1.1.8.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.9.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.10.1 = STRING: "Jul 28, 2015 2:03:00 PM CDT"#011.1.3.6.1.4.1.111.15.3.1.1.11.1 = STRING: "Availability"#011.1.3.6.1.4.1.111.15.3.1.1.12.1 = STRING: "Availability"#011.1.3.6.1.4.1.111.15.3.1.1.13.1 = STRING: "Metric Alert"#011.1.3.6.1.4.1.111.15.3.1.1.14.1 = STRING: "Response:State"#011.1.3.6.1.4.1.111.15.3.1.1.15.1 = STRING: "263"#011.1.3.6.1.4.1.111.15.3.1.1.16.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.17.1 = STRING: "No"#011.1.3.6.1.4.1.111.15.3.1.1.18.1 = STRING: "New"#011.1.3.6.1.4.1.111.15.3.1.1.19.1 = STRING: "None"#011.1.3.6.1.4.1.111.15.3.1.1.20.1 = STRING: "0"#011.1.3.6.1.4.1.111.15.3.1.1.21.1 = STRING: "kdblab01.snapon.com"#011.1.3.6.1.4.1.111.15.3.1.1.22.1 = STRING: "https://lisgrid01p.snapon.com:7799/em/redirect?pageType=TARGET_HOMEPAGE&targetName=kdblab01.snapon.com&targetType=oracle_database"#011.1.3.6.1.4.1.111.15.3.1.1.23.1 = STRING: "Database Instance"#011.1.3.6.1.4.1.111.15.3.1.1.24.1 = STRING: "kenrman01t.snapon.com"#011.1.3.6.1.4.1.111.15.3.1.1.25.1 = STRING: "SYSMAN"#011.1.3.6.1.4.1.111.15.3.1.1.26.1 = ""#011.1.3.6.1.4.1.111.15.3.1.1.27.1 = STRING: "11.2.0.3.0"#011.1.3.6.1.4.1.111.15.3.1.1.28.1 = STRING: "Operating System=SunOS, Platform=sparc"#011.1.3.6.1.4.1.111.15.3.1.1.29.1 = ""#011.1.3.6.1.4.1.111.
snapon_admin
Post
by snapon_admin » Wed Jul 29, 2015 10:03 am
Box293 wrote: Can you do the following:
Now go and send the trap from the sending device.
This will be spooled into a file in
/var/spool/snmptt/
Get a copy of this file and upload it here
Then:
Uhhh....I feel like this is a problem...
[root@lisl-ngos-01-pv snmp]# ll /var/spool/snmptt
total 796
-rw-r--r--. 1 root root 260 Jul 28 18:58 #snmptt-trap-1438127888185436
-rw-r--r--. 1 root root 260 Jul 28 18:58 #snmptt-trap-1438127888370275
-rw-r--r--. 1 root root 260 Jul 28 19:04 #snmptt-trap-1438128289737917
-rw-r--r--. 1 root root 260 Jul 28 19:04 #snmptt-trap-1438128289965182
-rw-r--r--. 1 root root 260 Jul 28 19:18 #snmptt-trap-1438129127321817
-rw-r--r--. 1 root root 260 Jul 28 19:18 #snmptt-trap-1438129127568445
-rw-r--r--. 1 root root 272 Jul 28 19:19 #snmptt-trap-1438129152211239
-rw-r--r--. 1 root root 270 Jul 28 19:19 #snmptt-trap-1438129182336151
-rw-r--r--. 1 root root 261 Jul 28 19:25 #snmptt-trap-1438129528940715
-rw-r--r--. 1 root root 261 Jul 28 19:25 #snmptt-trap-1438129529159434
-rw-r--r--. 1 root root 189 Jul 28 19:26 #snmptt-trap-1438129571021414
-rw-r--r--. 1 root root 261 Jul 28 19:32 #snmptt-trap-1438129942936309
-rw-r--r--. 1 root root 261 Jul 28 19:32 #snmptt-trap-1438129943183083
-rw-r--r--. 1 root root 227 Jul 28 19:40 #snmptt-trap-1438130409474034
-rw-r--r--. 1 root root 261 Jul 28 19:46 #snmptt-trap-1438130760460024
-rw-r--r--. 1 root root 261 Jul 28 19:46 #snmptt-trap-1438130760707030
-rw-r--r--. 1 root root 261 Jul 28 19:52 #snmptt-trap-1438131169321618
-rw-r--r--. 1 root root 261 Jul 28 19:52 #snmptt-trap-1438131169528574
-rw-r--r--. 1 root root 261 Jul 28 19:59 #snmptt-trap-1438131589725145
-rw-r--r--. 1 root root 261 Jul 28 19:59 #snmptt-trap-1438131590025862
-rw-r--r--. 1 root root 339 Jul 28 20:01 #snmptt-trap-1438131676001994
-rw-r--r--. 1 root root 305 Jul 28 20:01 #snmptt-trap-1438131683989820
-rw-r--r--. 1 root root 261 Jul 28 20:05 #snmptt-trap-1438131952330526
-rw-r--r--. 1 root root 261 Jul 28 20:05 #snmptt-trap-1438131952489014
-rw-r--r--. 1 root root 255 Jul 28 20:12 #snmptt-trap-1438132379185320
-rw-r--r--. 1 root root 255 Jul 28 20:12 #snmptt-trap-1438132379352512
-rw-r--r--. 1 root root 261 Jul 28 20:13 #snmptt-trap-1438132426934718
-rw-r--r--. 1 root root 261 Jul 28 20:13 #snmptt-trap-1438132427184995
-rw-r--r--. 1 root root 338 Jul 28 20:21 #snmptt-trap-1438132907226918
-rw-r--r--. 1 root root 304 Jul 28 20:21 #snmptt-trap-1438132915085906
-rw-r--r--. 1 root root 188 Jul 28 20:26 #snmptt-trap-1438133170450417
-rw-r--r--. 1 root root 226 Jul 28 20:40 #snmptt-trap-1438134009263633
-rw-r--r--. 1 root root 250 Jul 28 20:43 #snmptt-trap-1438134226063924
-rw-r--r--. 1 root root 255 Jul 28 20:52 #snmptt-trap-1438134734472567
-rw-r--r--. 1 root root 255 Jul 28 20:52 #snmptt-trap-1438134734697221
-rw-r--r--. 1 root root 255 Jul 28 20:56 #snmptt-trap-1438134977398504
-rw-r--r--. 1 root root 255 Jul 28 20:56 #snmptt-trap-1438134977596429
-rw-r--r--. 1 root root 255 Jul 28 21:04 #snmptt-trap-1438135462790091
-rw-r--r--. 1 root root 255 Jul 28 21:04 #snmptt-trap-1438135463032273
-rw-r--r--. 1 root root 272 Jul 28 21:10 #snmptt-trap-1438135840242257
-rw-r--r--. 1 root root 270 Jul 28 21:10 #snmptt-trap-1438135850232137
-rw-r--r--. 1 root root 340 Jul 28 21:14 #snmptt-trap-1438136098579733
-rw-r--r--. 1 root root 268 Jul 28 21:14 #snmptt-trap-1438136098686369
-rw-r--r--. 1 root root 337 Jul 28 21:14 #snmptt-trap-1438136098774152
-rw-r--r--. 1 root root 268 Jul 28 21:14 #snmptt-trap-1438136098865796
-rw-r--r--. 1 root root 340 Jul 28 21:15 #snmptt-trap-1438136103130068
-rw-r--r--. 1 root root 270 Jul 28 21:15 #snmptt-trap-1438136103220835
-rw-r--r--. 1 root root 340 Jul 28 21:15 #snmptt-trap-1438136104080743
-rw-r--r--. 1 root root 270 Jul 28 21:15 #snmptt-trap-1438136104346878
-rw-r--r--. 1 root root 343 Jul 28 21:15 #snmptt-trap-1438136104440013
-rw-r--r--. 1 root root 274 Jul 28 21:15 #snmptt-trap-1438136104531527
-rw-r--r--. 1 root root 305 Jul 28 21:15 #snmptt-trap-1438136104653716
-rw-r--r--. 1 root root 289 Jul 28 21:15 #snmptt-trap-1438136104752344
-rw-r--r--. 1 root root 305 Jul 28 21:15 #snmptt-trap-1438136104853096
-rw-r--r--. 1 root root 289 Jul 28 21:15 #snmptt-trap-1438136104949023
-rw-r--r--. 1 root root 308 Jul 28 21:15 #snmptt-trap-1438136105105688
-rw-r--r--. 1 root root 293 Jul 28 21:15 #snmptt-trap-1438136105207699
-rw-r--r--. 1 root root 305 Jul 28 21:15 #snmptt-trap-1438136105933717
-rw-r--r--. 1 root root 287 Jul 28 21:15 #snmptt-trap-1438136106053906
-rw-r--r--. 1 root root 302 Jul 28 21:15 #snmptt-trap-1438136106141818
-rw-r--r--. 1 root root 287 Jul 28 21:15 #snmptt-trap-1438136106229490
-rw-r--r--. 1 root root 342 Jul 28 21:15 #snmptt-trap-1438136106615093
-rw-r--r--. 1 root root 274 Jul 28 21:15 #snmptt-trap-1438136106710298
-rw-r--r--. 1 root root 307 Jul 28 21:15 #snmptt-trap-1438136107881175
-rw-r--r--. 1 root root 293 Jul 28 21:15 #snmptt-trap-1438136107969530
-rw-r--r--. 1 root root 269 Jul 28 21:21 #snmptt-trap-1438136477930049
-rw-r--r--. 1 root root 342 Jul 28 21:21 #snmptt-trap-1438136497059721
-rw-r--r--. 1 root root 274 Jul 28 21:21 #snmptt-trap-1438136497147856
-rw-r--r--. 1 root root 307 Jul 28 21:21 #snmptt-trap-1438136497235536
-rw-r--r--. 1 root root 293 Jul 28 21:21 #snmptt-trap-1438136497324790
-rw-r--r--. 1 root root 272 Jul 28 21:21 #snmptt-trap-1438136497922335
-rw-r--r--. 1 root root 340 Jul 28 21:21 #snmptt-trap-1438136517940995
-rw-r--r--. 1 root root 268 Jul 28 21:21 #snmptt-trap-1438136518036163
-rw-r--r--. 1 root root 337 Jul 28 21:21 #snmptt-trap-1438136518126602
-rw-r--r--. 1 root root 268 Jul 28 21:21 #snmptt-trap-1438136518217032
-rw-r--r--. 1 root root 305 Jul 28 21:21 #snmptt-trap-1438136518317630
-rw-r--r--. 1 root root 287 Jul 28 21:21 #snmptt-trap-1438136518405101
-rw-r--r--. 1 root root 302 Jul 28 21:21 #snmptt-trap-1438136518495702
-rw-r--r--. 1 root root 287 Jul 28 21:21 #snmptt-trap-1438136518586611
-rw-r--r--. 1 root root 188 Jul 28 21:26 #snmptt-trap-1438136769876577
-rw-r--r--. 1 root root 269 Jul 28 21:27 #snmptt-trap-1438136877949077
-rw-r--r--. 1 root root 272 Jul 28 21:28 #snmptt-trap-1438136897947176
-rw-r--r--. 1 root root 226 Jul 28 21:40 #snmptt-trap-1438137611280396
-rw-r--r--. 1 root root 1273 Jul 28 22:02 #snmptt-trap-1438138941511041
-rw-r--r--. 1 root root 1172 Jul 28 22:05 #snmptt-trap-1438139151201438
-rw-r--r--. 1 root root 3580 Jul 28 22:14 #snmptt-trap-1438139655286907
-rw-r--r--. 1 root root 3611 Jul 28 22:14 #snmptt-trap-1438139655406327
-rw-r--r--. 1 root root 3593 Jul 28 22:14 #snmptt-trap-1438139655655285
-rw-r--r--. 1 root root 3580 Jul 28 22:20 #snmptt-trap-1438140036871534
-rw-r--r--. 1 root root 3593 Jul 28 22:20 #snmptt-trap-1438140036981981
-rw-r--r--. 1 root root 3611 Jul 28 22:20 #snmptt-trap-1438140037119101
-rw-r--r--. 1 root root 3713 Jul 28 22:22 #snmptt-trap-1438140120095122
-rw-r--r--. 1 root root 3588 Jul 28 22:22 #snmptt-trap-1438140152982375
-rw-r--r--. 1 root root 188 Jul 28 22:26 #snmptt-trap-1438140369279246
-rw-r--r--. 1 root root 337 Jul 28 22:28 #snmptt-trap-1438140539456848
-rw-r--r--. 1 root root 268 Jul 28 22:28 #snmptt-trap-1438140539542414
-rw-r--r--. 1 root root 302 Jul 28 22:28 #snmptt-trap-1438140539627859
-rw-r--r--. 1 root root 287 Jul 28 22:28 #snmptt-trap-1438140539717368
-rw-r--r--. 1 root root 342 Jul 28 22:29 #snmptt-trap-1438140541345304
-rw-r--r--. 1 root root 274 Jul 28 22:29 #snmptt-trap-1438140541431675
-rw-r--r--. 1 root root 307 Jul 28 22:29 #snmptt-trap-1438140541526640
-rw-r--r--. 1 root root 293 Jul 28 22:29 #snmptt-trap-1438140541707631
-rw-r--r--. 1 root root 340 Jul 28 22:29 #snmptt-trap-1438140541870043
-rw-r--r--. 1 root root 268 Jul 28 22:29 #snmptt-trap-1438140542001874
-rw-r--r--. 1 root root 305 Jul 28 22:29 #snmptt-trap-1438140542124015
-rw-r--r--. 1 root root 287 Jul 28 22:29 #snmptt-trap-1438140542214598
-rw-r--r--. 1 root root 226 Jul 28 22:40 #snmptt-trap-1438141214040912
-rw-r--r--. 1 root root 340 Jul 28 22:48 #snmptt-trap-1438141709721264
-rw-r--r--. 1 root root 268 Jul 28 22:48 #snmptt-trap-1438141709839440
-rw-r--r--. 1 root root 340 Jul 28 22:48 #snmptt-trap-1438141714273617
-rw-r--r--. 1 root root 270 Jul 28 22:48 #snmptt-trap-1438141714377833
-rw-r--r--. 1 root root 342 Jul 28 22:48 #snmptt-trap-1438141714935054
-rw-r--r--. 1 root root 274 Jul 28 22:48 #snmptt-trap-1438141715025279
-rw-r--r--. 1 root root 343 Jul 28 22:48 #snmptt-trap-1438141715117039
-rw-r--r--. 1 root root 274 Jul 28 22:48 #snmptt-trap-1438141715211992
-rw-r--r--. 1 root root 305 Jul 28 22:48 #snmptt-trap-1438141717667855
-rw-r--r--. 1 root root 289 Jul 28 22:48 #snmptt-trap-1438141717762519
-rw-r--r--. 1 root root 307 Jul 28 22:48 #snmptt-trap-1438141718341398
-rw-r--r--. 1 root root 293 Jul 28 22:48 #snmptt-trap-1438141718430471
-rw-r--r--. 1 root root 308 Jul 28 22:48 #snmptt-trap-1438141718522266
-rw-r--r--. 1 root root 293 Jul 28 22:48 #snmptt-trap-1438141718614395
-rw-r--r--. 1 root root 305 Jul 28 22:48 #snmptt-trap-1438141724815856
-rw-r--r--. 1 root root 287 Jul 28 22:48 #snmptt-trap-1438141724908172
-rw-r--r--. 1 root root 340 Jul 28 22:48 #snmptt-trap-1438141731285942
-rw-r--r--. 1 root root 270 Jul 28 22:48 #snmptt-trap-1438141731370753
-rw-r--r--. 1 root root 305 Jul 28 22:48 #snmptt-trap-1438141731456197
-rw-r--r--. 1 root root 289 Jul 28 22:48 #snmptt-trap-1438141731543387
-rw-r--r--. 1 root root 261 Jul 28 23:14 #snmptt-trap-1438143281307694
-rw-r--r--. 1 root root 260 Jul 28 23:15 #snmptt-trap-1438143309437794
-rw-r--r--. 1 root root 188 Jul 28 23:26 #snmptt-trap-1438143968682518
-rw-r--r--. 1 root root 261 Jul 28 23:27 #snmptt-trap-1438144036697544
-rw-r--r--. 1 root root 255 Jul 28 23:32 #snmptt-trap-1438144365576598
-rw-r--r--. 1 root root 261 Jul 28 23:35 #snmptt-trap-1438144521907831
-rw-r--r--. 1 root root 261 Jul 28 23:39 #snmptt-trap-1438144773491134
-rw-r--r--. 1 root root 256 Jul 28 23:39 #snmptt-trap-1438144783603280
-rw-r--r--. 1 root root 226 Jul 28 23:40 #snmptt-trap-1438144808696336
-rw-r--r--. 1 root root 259 Jul 28 23:42 #snmptt-trap-1438144949637816
-rw-r--r--. 1 root root 259 Jul 28 23:44 #snmptt-trap-1438145077244211
-rw-r--r--. 1 root root 261 Jul 28 23:50 #snmptt-trap-1438145400313531
-rw-r--r--. 1 root root 259 Jul 28 23:56 #snmptt-trap-1438145769850517
-rw-r--r--. 1 root root 261 Jul 28 23:58 #snmptt-trap-1438145890384844
-rw-r--r--. 1 root root 259 Jul 29 00:08 #snmptt-trap-1438146525189310
-rw-r--r--. 1 root root 261 Jul 29 00:11 #snmptt-trap-1438146685921480
-rw-r--r--. 1 root root 261 Jul 29 00:12 #snmptt-trap-1438146778547180
-rw-r--r--. 1 root root 259 Jul 29 00:14 #snmptt-trap-1438146884685750
-rw-r--r--. 1 root root 272 Jul 29 00:16 #snmptt-trap-1438147012276653
-rw-r--r--. 1 root root 270 Jul 29 00:17 #snmptt-trap-1438147022287666
-rw-r--r--. 1 root root 188 Jul 29 00:26 #snmptt-trap-1438147568102938
-rw-r--r--. 1 root root 272 Jul 29 00:29 #snmptt-trap-1438147785866876
-rw-r--r--. 1 root root 270 Jul 29 00:29 #snmptt-trap-1438147797261307
-rw-r--r--. 1 root root 256 Jul 29 00:37 #snmptt-trap-1438148226827129
-rw-r--r--. 1 root root 272 Jul 29 00:39 #snmptt-trap-1438148380306948
-rw-r--r--. 1 root root 270 Jul 29 00:39 #snmptt-trap-1438148390257970
-rw-r--r--. 1 root root 226 Jul 29 00:40 #snmptt-trap-1438148409735106
-rw-r--r--. 1 root root 272 Jul 29 00:43 #snmptt-trap-1438148622468520
-rw-r--r--. 1 root root 270 Jul 29 00:43 #snmptt-trap-1438148632477465
-rw-r--r--. 1 root root 259 Jul 29 00:46 #snmptt-trap-1438148780330901
-rw-r--r--. 1 root root 261 Jul 29 00:46 #snmptt-trap-1438148792904336
-rw-r--r--. 1 root root 272 Jul 29 00:52 #snmptt-trap-1438149175856656
-rw-r--r--. 1 root root 270 Jul 29 00:53 #snmptt-trap-1438149186278671
-rw-r--r--. 1 root root 259 Jul 29 00:55 #snmptt-trap-1438149336576543
-rw-r--r--. 1 root root 259 Jul 29 00:55 #snmptt-trap-1438149349766472
-rw-r--r--. 1 root root 261 Jul 29 00:56 #snmptt-trap-1438149408826440
-rw-r--r--. 1 root root 272 Jul 29 01:11 #snmptt-trap-1438150310620971
-rw-r--r--. 1 root root 270 Jul 29 01:12 #snmptt-trap-1438150324634529
-rw-r--r--. 1 root root 256 Jul 29 01:20 #snmptt-trap-1438150815690548
-rw-r--r--. 1 root root 188 Jul 29 01:26 #snmptt-trap-1438151167540682
-rw-r--r--. 1 root root 272 Jul 29 01:33 #snmptt-trap-1438151599216599
-rw-r--r--. 1 root root 270 Jul 29 01:33 #snmptt-trap-1438151613228875
-rw-r--r--. 1 root root 226 Jul 29 01:40 #snmptt-trap-1438152008783611
-rw-r--r--. 1 root root 272 Jul 29 01:44 #snmptt-trap-1438152243275503
-rw-r--r--. 1 root root 270 Jul 29 01:44 #snmptt-trap-1438152253283008
-rw-r--r--. 1 root root 188 Jul 29 02:26 #snmptt-trap-1438154766945425
-rw-r--r--. 1 root root 272 Jul 29 02:26 #snmptt-trap-1438154802352396
-rw-r--r--. 1 root root 270 Jul 29 02:26 #snmptt-trap-1438154812339889
-rw-r--r--. 1 root root 272 Jul 29 02:27 #snmptt-trap-1438154822609461
-rw-r--r--. 1 root root 270 Jul 29 02:27 #snmptt-trap-1438154832631795
-rw-r--r--. 1 root root 226 Jul 29 02:40 #snmptt-trap-1438155608888893
-rw-r--r--. 1 root root 259 Jul 29 02:48 #snmptt-trap-1438156123962279
-rw-r--r--. 1 root root 188 Jul 29 03:26 #snmptt-trap-1438158366363860
-rw-r--r--. 1 root root 226 Jul 29 03:40 #snmptt-trap-1438159208881856
-rw-r--r--. 1 root root 332 Jul 29 04:05 #snmptt-trap-1438160710134797
-rw-r--r--. 1 root root 304 Jul 29 04:05 #snmptt-trap-1438160734099570
-rw-r--r--. 1 root root 188 Jul 29 04:26 #snmptt-trap-1438161965783571
-rw-r--r--. 1 root root 259 Jul 29 04:34 #snmptt-trap-1438162495142482
-rw-r--r--. 1 root root 226 Jul 29 04:40 #snmptt-trap-1438162808937696
-rw-r--r--. 1 root root 253 Jul 29 04:40 #snmptt-trap-1438162826500979
-rw-r--r--. 1 root root 254 Jul 29 04:52 #snmptt-trap-1438163534736343
-rw-r--r--. 1 root root 188 Jul 29 05:26 #snmptt-trap-1438165565205663
-rw-r--r--. 1 root root 226 Jul 29 05:36 #snmptt-trap-1438166214355624
-rw-r--r--. 1 root root 332 Jul 29 05:50 #snmptt-trap-1438167049642479
-rw-r--r--. 1 root root 304 Jul 29 05:51 #snmptt-trap-1438167060134910
-rw-r--r--. 1 root root 253 Jul 29 07:20 #snmptt-trap-1438172436050155
-rw-r--r--. 1 root root 253 Jul 29 07:20 #snmptt-trap-1438172436137967
-rw-r--r--. 1 root root 253 Jul 29 07:24 #snmptt-trap-1438172680857592
-rw-r--r--. 1 root root 253 Jul 29 07:24 #snmptt-trap-1438172681110927
-rw-r--r--. 1 root root 253 Jul 29 07:32 #snmptt-trap-1438173171844232
-rw-r--r--. 1 root root 253 Jul 29 07:32 #snmptt-trap-1438173172088315
-rw-r--r--. 1 root root 1246 Jul 29 08:46 #snmptt-trap-1438177598080723
[root@lisl-ngos-01-pv snmp]# service snmptt status
snmptt (pid 28078) is running...
snapon_admin
Post
by snapon_admin » Wed Jul 29, 2015 10:20 am
Alright I cleared the spool and here's the trap that is coming up unknown for some reason:
<UNKNOWN>
UDP: [<REDACTED>]:9896->[<REDACTED>]
.1.3.6.1.2.1.1.3.0 16:0:09:11.04
.1.3.6.1.6.3.1.1.4.1.0 .1.3.6.1.4.1.111.15.2
.1.3.6.1.4.1.111.15.3.1.1.2.1 "NOTIF_NORMAL"
.1.3.6.1.4.1.111.15.3.1.1.3.1 "The listener is down: TNS-12541: TNS:no listener ."
.1.3.6.1.4.1.111.15.3.1.1.4.1 "https://lisgrid01p.snapon.com:7799/em/redirect?pageType=sdk-core-event-console-detailEvent&issueID=1AC3FC17982827E0E054020820F4DF2F"
.1.3.6.1.4.1.111.15.3.1.1.5.1 "Fatal"
.1.3.6.1.4.1.111.15.3.1.1.6.1 "FATAL"
.1.3.6.1.4.1.111.15.3.1.1.7.1 "0"
.1.3.6.1.4.1.111.15.3.1.1.8.1 ""
.1.3.6.1.4.1.111.15.3.1.1.9.1 ""
.1.3.6.1.4.1.111.15.3.1.1.10.1 "Jul 29, 2015 10:14:05 AM CDT"
.1.3.6.1.4.1.111.15.3.1.1.11.1 "Availability"
.1.3.6.1.4.1.111.15.3.1.1.12.1 "Availability"
.1.3.6.1.4.1.111.15.3.1.1.13.1 "Target Availability"
.1.3.6.1.4.1.111.15.3.1.1.14.1 "Status"
.1.3.6.1.4.1.111.15.3.1.1.15.1 "282"
.1.3.6.1.4.1.111.15.3.1.1.16.1 ""
.1.3.6.1.4.1.111.15.3.1.1.17.1 "No"
.1.3.6.1.4.1.111.15.3.1.1.18.1 "New"
.1.3.6.1.4.1.111.15.3.1.1.19.1 "None"
.1.3.6.1.4.1.111.15.3.1.1.20.1 "0"
.1.3.6.1.4.1.111.15.3.1.1.21.1 "LISTENER_KDBLAB01_kenrman01t.snapon.com"
.1.3.6.1.4.1.111.15.3.1.1.22.1 "https://lisgrid01p.snapon.com:7799/em/redirect?pageType=TARGET_HOMEPAGE&targetName=LISTENER_KDBLAB01_kenrman01t.snapon.com&targetType=oracle_listener"
.1.3.6.1.4.1.111.15.3.1.1.23.1 "Listener"
.1.3.6.1.4.1.111.15.3.1.1.24.1 "kenrman01t.snapon.com"
.1.3.6.1.4.1.111.15.3.1.1.25.1 "SYSMAN"
.1.3.6.1.4.1.111.15.3.1.1.26.1 ""
.1.3.6.1.4.1.111.15.3.1.1.27.1 "11.2.0.3.0"
.1.3.6.1.4.1.111.15.3.1.1.28.1 "Operating System=SunOS, Platform=sparc"
.1.3.6.1.4.1.111.15.3.1.1.29.1 ""
.1.3.6.1.4.1.111.15.3.1.1.30.1 ""
.1.3.6.1.4.1.111.15.3.1.1.31.1 ""
.1.3.6.1.4.1.111.15.3.1.1.32.1 ""
.1.3.6.1.4.1.111.15.3.1.1.33.1 ""
.1.3.6.1.4.1.111.15.3.1.1.34.1 ""
.1.3.6.1.4.1.111.15.3.1.1.35.1 ""
.1.3.6.1.4.1.111.15.3.1.1.36.1 ""
.1.3.6.1.4.1.111.15.3.1.1.37.1 ""
.1.3.6.1.4.1.111.15.3.1.1.38.1 ""
.1.3.6.1.4.1.111.15.3.1.1.39.1 "Nagios Alerts"
.1.3.6.1.4.1.111.15.3.1.1.40.1 "Nagios Alerts,Nagios Rule 1"
.1.3.6.1.4.1.111.15.3.1.1.41.1 "SYSMAN"
.1.3.6.1.4.1.111.15.3.1.1.42.1 "1AC3FC17982827E0E054020820F4DF2F"
.1.3.6.1.4.1.111.15.3.1.1.43.1 ""
.1.3.6.1.4.1.111.15.3.1.1.44.1 ""
.1.3.6.1.4.1.111.15.3.1.1.45.1 ""
.1.3.6.1.4.1.111.15.3.1.1.46.1 "The listener is down: TNS-12541: TNS:no listener ., Incident created by rule (Name = Snap-on Rule Set for All Targets, Incident creation rule for a Target Down availability status; Owner = SYSMAN)."
.1.3.6.1.4.1.111.15.3.1.1.47.1 ""
.1.3.6.1.4.1.111.15.3.1.1.48.1 ""
.1.3.6.1.4.1.111.15.3.1.1.49.1 ""
.1.3.6.1.4.1.111.15.3.1.1.50.1 ""
.1.3.6.1.4.1.111.15.3.1.1.51.1 "Neither Cause Nor Symptom"
.1.3.6.1.4.1.111.15.3.1.1.61.1 "Availability status=Down"
.1.3.6.1.4.1.111.15.3.1.1.62.1 "Severity GUID=1AC3FC17982427E0E054020820F4DF2F"
.1.3.6.1.4.1.111.15.3.1.1.63.1 "Availability Sub-status=99"
.1.3.6.1.4.1.111.15.3.1.1.64.1 "Transition Severity=25"
.1.3.6.1.4.1.111.15.3.1.1.65.1 "Response metric GUID=1EA69E018E163E3E323609D334EE8E20"
.1.3.6.1.4.1.111.15.3.1.1.66.1 "Severity GUID of the first severity in the availability cycle=1BFBE40CFE180EB1E054020820F4DF2F"
.1.3.6.1.4.1.111.15.3.1.1.67.1 ""
.1.3.6.1.4.1.111.15.3.1.1.68.1 ""
.1.3.6.1.4.1.111.15.3.1.1.69.1 ""
.1.3.6.1.4.1.111.15.3.1.1.70.1 ""
.1.3.6.1.4.1.111.15.3.1.1.71.1 ""
.1.3.6.1.4.1.111.15.3.1.1.72.1 ""
.1.3.6.1.4.1.111.15.3.1.1.73.1 ""
.1.3.6.1.4.1.111.15.3.1.1.74.1 ""
.1.3.6.1.4.1.111.15.3.1.1.75.1 ""
.1.3.6.1.4.1.111.15.3.1.1.76.1 ""
.1.3.6.1.4.1.111.15.3.1.1.77.1 ""
.1.3.6.1.4.1.111.15.3.1.1.78.1 ""
.1.3.6.1.4.1.111.15.3.1.1.79.1 ""
.1.3.6.1.4.1.111.15.3.1.1.80.1 ""
.1.3.6.1.4.1.111.15.3.1.1.81.1 ""
.1.3.6.1.4.1.111.15.3.1.1.82.1 ""
.1.3.6.1.4.1.111.15.3.1.1.83.1 ""
.1.3.6.1.4.1.111.15.3.1.1.84.1 ""
.1.3.6.1.4.1.111.15.3.1.1.85.1 ""
.1.3.6.1.6.3.18.1.3.0 <REDACTED>
Keep in mind this particular trap WAS working before I included the Match statements.
snapon_admin
Post
by snapon_admin » Wed Jul 29, 2015 3:42 pm
I think I'm onto something here. For the MATCH statement, it looks like if you use a regular expression you need to surround it in parenthesis. So instead of:
It should be:
ssax
Dreams In Code
Posts: 7682 Joined: Wed Feb 11, 2015 12:54 pm
Post
by ssax » Wed Jul 29, 2015 4:46 pm
This should work for you.
EVENT oraEM4Traps .1.3.6.1.4.1.111.15.2 "Status Events" Normal
FORMAT The variables included in the oraEM4Traps trap. $*
EXEC /usr/local/bin/snmptraphandling.py "$r" "SNMP Traps" "$s" "$@" "$-*" "$4 Status Event occurred on $23 at $9. $2 $Fn"
MATCH $5: (CLEAR)
MATCH $5: (INFORMATION)
This is a sample Event Message to test the SNMP notification delivery to the SNMP Manager. The contents of this messages are all sample data.
Variables:
1: oraEMNGEventNotifType
2: oraEMNGEventMessage
3: oraEMNGEventMessageURL
4: oraEMNGEventSeverity
5: oraEMNGEventSeverityCode
6: oraEMNGEventRepeatCount
7: oraEMNGEventActionMsg
8: oraEMNGEventOccurrenceTime
9: oraEMNGEventReportedTime
10: oraEMNGEventCategories
11: oraEMNGEventCategoryCodes
12: oraEMNGEventType
13: oraEMNGEventName
14: oraEMNGAssocIncidentId
15: oraEMNGAssocIncidentOwner
16: oraEMNGAssocIncidentAcked
17: oraEMNGAssocIncidentStatus
18: oraEMNGAssocIncidentPriority
19: oraEMNGAssocIncidentEscLevel
20: oraEMNGEventTargetName
21: oraEMNGEventTargetNameURL
22: oraEMNGEventTargetType
23: oraEMNGEventHostName
24: oraEMNGEventTargetOwner
25: oraEMNGEventTgtLifeCycleStatus
26: oraEMNGEventTargetVersion
27: oraEMNGEventUserDefinedTgtProp
28: oraEMNGEventSourceObjName
29: oraEMNGEventSourceObjNameURL
30: oraEMNGEventSourceObjType
31: oraEMNGEventSourceObjSubType
32: oraEMNGEventSourceObjOwner
33: oraEMNGEventCAJobName
34: oraEMNGEventCAJobStatus
35: oraEMNGEventCAJobOwner
36: oraEMNGEventCAJobStepOutput
37: oraEMNGEventCAJobType
38: oraEMNGEventRuleSetName
39: oraEMNGEventRuleName
40: oraEMNGEventRuleOwner
41: oraEMNGEventSequenceId
42: oraEMNGEventRCADetails
43: oraEMNGEventContextAttrs
44: oraEMNGEventUserComments
45: oraEMNGEventTypeAttr1
46: oraEMNGEventTypeAttr2
47: oraEMNGEventTypeAttr3
48: oraEMNGEventTypeAttr4
49: oraEMNGEventTypeAttr5
50: oraEMNGEventTypeAttr6
51: oraEMNGEventTypeAttr7
52: oraEMNGEventTypeAttr8
53: oraEMNGEventTypeAttr9
54: oraEMNGEventTypeAttr10
55: oraEMNGEventTypeAttr11
56: oraEMNGEventTypeAttr12
57: oraEMNGEventTypeAttr13
58: oraEMNGEventTypeAttr14
59: oraEMNGEventTypeAttr15
60: oraEMNGEventTypeAttr16
61: oraEMNGEventTypeAttr17
62: oraEMNGEventTypeAttr18
63: oraEMNGEventTypeAttr19
64: oraEMNGEventTypeAttr20
65: oraEMNGEventTypeAttr21
66: oraEMNGEventTypeAttr22
67: oraEMNGEventTypeAttr23
68: oraEMNGEventTypeAttr24
69: oraEMNGEventTypeAttr25
EDESC
EVENT oraEM4Traps .1.3.6.1.4.1.111.15.2 "Status Events" Warning
MATCH $5: (WARNING)
Variables:
EDESC
EVENT oraEM4Traps .1.3.6.1.4.1.111.15.2 "Status Events" Critical
MATCH $5: (FATAL)
MATCH $5: (CRITICAL)
Variables:
EDESC
snapon_admin
Post
by snapon_admin » Thu Jul 30, 2015 11:32 am
Yep, already did that and tested it. Just wanted to post it here in case anyone else needs the info and stumbles upon this thread in the future. Safe to lock this one up, if something else comes up I'll open another thread and bug you in that one. Thanks for all the tips guys!
ssax
Dreams In Code
Post
by ssax » Thu Jul 30, 2015 1:23 pm
I didn't see your post until I was already done figuring it out so I posted it anyways. Marking as resolved and locking.
