Passive checks passing Haproxy to CORE
ashleydrees
Re: Passive checks passing Haproxy to CORE
Post by ashleydrees »
Box293..
Lets also check we don't have multiple instances of nagios running:
ps -ef | grep nagios.cfg
root      6957  8995  0 12:14 pts/4    00:00:00 grep --color=auto nagios.cfg
This is not on the Nagios Core incidence - it is on the NCPA remote "client" i am trying to get to send passive checks back.
root 989 1 0 Nov05 ? 00:03:34 ./ncpa_posix_listener --start
root 12161 1 0 Nov05 ? 00:00:16 ./ncpa_posix_passive --start
ashleydrees wrote: DEBUG Running process with command line: `/usr/local/ncpa/plugins/check_http -H nagios.domain.tld -u http://nagios.domain.tld/robots.txt`
Which will return an OK as the robots.txt is actually there.
Is this command running from the local machine?
Can you elaborate more on your setup in regards to HA / pfSense? There are quite a lot of components in play at this point which may mean some more forwarding needs to be setup.
