Error while Plotting Graphs using Network Switch Router
Re: Error while Plotting Graphs using Network Switch Router
Can you PM me the profile.zip?
Admin->System Profile->Download Profile
nomanntl
Post by nomanntl »
Required file sent as PM. Waiting for your response.
Thank you in anticipation.
I looked through the logs and I noticed the following error in the apache error log:
[Tue Aug 04 15:40:26 2015] [error] [client ::1] PHP Fatal error: Maximum execution time of 60 seconds exceeded in /usr/local/nagiosxi/html/includes/components/ccm/classes/config_class.php on line 1012
Most probably configuration never applies as the page is timing out. Please, increase the resource limits in the php.ini file, especially the "max_execution_time". For more info, check out our FAQ wiki page here:
https://support.nagios.com/wiki/index.p ... _Completes
In addition to this, the mysqld.log came up empty (0 bytes) in the profile. Can you run the following command and show the output in code wraps?
tail -50 /var/log/mysqld.log
Thank you!
Can you go to Admin > License Information and let us know the status of the licensing?
nomanntl
Post by nomanntl »
The following limits have been applied:
max_execution_time = 120
max_input_time = 120
The mysql.log file is empty.
Please suggest further
Post by Box293 »
nomanntl wrote:max_execution_time = 120
I suggest 300, if that doesn't work then 600. Don't forget to restart httpd after making these changes.
When applying config, tail the httpd error_log
tail /var/log/httpd/error_log -f
nomanntl
Post by nomanntl »
Issue still persist.
Changed the execution timeout value to 600. Attached is the error log.
Please suggest further.
jdalrymple
Skynet Drone
Post by jdalrymple »
Where did the timestamps go from your error_log? Generally they're just noise, but in this case they could add some context to the problem for us.
