I understand the first part. yes, the dcn host it not part of any hostgroup. however the default queue runs on a different worker ( NAGIOS XI Server also is a worker and it supposed to the default queue)
the new worker only supposed to do host checks that are on the dca1 queue and this is not happening
host checks are being done by different gearman
jdalrymple
- Skynet Drone
Re: host checks are being done by different gearman
If you want it to stop processing host checks for all other hosts you'll have to change this to hosts=no.Code: Select all
# defines if the worker should execute # host checks. hosts=yes
As for why it's not processing dca checks, probably because it's too busy with other hosts. You have hundreds of other hosts, but only 70 or so dca hosts as I recall.
I always though that settings was to allow this worker to do host check only for the queues that are defined on the same config file
jdalrymple
- Skynet Drone
It's deceptive.
'hosts=yes' means it will handle all hosts that aren't part of another hostgroup queue. If you add a hostgroup queue though, the worker will execute host checks for the hosts in that queue even with the `hosts=no' in place, and also service checks if you have those enabled.
that worked. thanks. you can close the ticket
