Wizard is not working.
paulol
Re: Wizard is not working.
Post by paulol »
Follows the file.
ssax
Dreams In Code
Post by ssax »
Looks like your postgresql DB is having issues, did you guys do any customization to the postgresql settings?
Try running a repair on it.
As root run the following:
service postgresql stop
Change to the postgres account:
su postgres
Run these commands to single user fix the psql databases:
postgres --single -D /var/lib/pgsql/data/ nagiosxi
backend> vacuum full
PRESS CTRL-D TO BREAK
postgres --single -D /var/lib/pgsql/data/ postgres
Then run these commands:
exit
service postgresql start
Then try the wizard again and let us know the results.
paulol
Post by paulol »
No, I didnt.
I did everything you told me to do and the problem was not solved.
[root@DOUAI var]# service postgresql stop
Stopping postgresql service: [ OK ]
[root@DOUAI var]# su postgres
bash-4.1$ postgres --single -D /var/lib/pgsql/data/ nagiosxi
PostgreSQL stand-alone backend 8.4.20
bash-4.1$ postgres --single -D /var/lib/pgsql/data/ postgres
[root@DOUAI var]# service postgresql start
Starting postgresql service: [ OK ]
paulol
Post by paulol »
I enabled the parameter standard_conforming_strings on file postgresql.conf to ON and the following error stopped, but the wizards still doesn't work:
WARNING: nonstandard use of \\ in a string literal at character 98
HINT: Use the escape string syntax for backslashes, e.g., E'\\'.
ssax
Dreams In Code
Post by ssax »
I think at this point we should move this into a ticket so that we can setup a remote session.
Please send an email to [email protected] with a descriptive subject and the body detailing this issue with a link back to this thread.
paulol
Post by paulol »
Sean you can close this thread the problem was already solved.
I found a file in /usr/my.cnf that was set this parameter.
[mysqld]
sql-mode = STRICT_TRANS_TABLES,NO_ENGINE_SUBSTITUTION
and i changed to :
[mysqld]
sql-mode = NO_ENGINE_SUBSTITUTION
Thx.
hsmith
Agent Smith
Post by hsmith »
paulol wrote:Sean you can close this thread the problem was already solved.
[mysqld]
and i changed to :
[mysqld]
Thx.
Thank you for posting the resolution - we always appreciate the feedback.
Closing this one.
Former Nagios Employee.
me.
