Script to find nmon for AIX
jdalrymple
Skynet Drone
Re: Script to find nmon for AIX
Post by jdalrymple »
Lot's of options. As I mentioned, you're a good portion of the way there with your currently selected plugin. You'll just need to get NRPE compiled and installed on your platform:
This document assumes Linux, if you are an AIX admin though most of the concepts should make sense to you:
Once that's compiled and configured, the setup you currently have can be used to send the data back to the Nagios server.
raamardhani7
Post by raamardhani7 »
jdalrymple wrote:Lot's of options. As I mentioned, you're a good portion of the way there with your currently selected plugin. You'll just need to get NRPE compiled and installed on your platform:
Hi Jdalrymple,
I have installed the binaries and NRPE plugin is working fine. I wanted to have nmon monitored :)
Thanks again.
jdalrymple
Skynet Drone
raamardhani7 wrote:I have installed the binaries and NRPE plugin is working fine. I wanted to have nmon monitored
Perfect, and it seems your cron is working, so the only thing left is to add these commands to your nrpe.cfg. Something like the following at the bottom should work:
command[check_nmon_cpu]=/path/to/check_nmon -F /etc/perf/nmonserver_name.nmon -k CPU_ID -s User%,Sys%,Wait%,Idl
command[check_nmon_pages]/path/to/check_nmon -F /etc/perf/nmonserver_name.nmon -k PAGE -s pgin,pgout,pgsin,pgsout
command[check_nmon_netio]=/path/to/check_nmon -F /etc/perf/nmonserver_name.nmon -k NET,NETERROR -s en0-read-KB/s,en0-write-KB/s,en0-ierrs,en0-oerrs,en0-collisions
command[check_nmon_diskio]=/path/to/check_nmon -F /etc/perf/nmonserver_name.nmon -k IOADAPT -s fcsx_read-KB/s,fcsx_write-KB/s,fcsx_xfer-tps
command[check_nmon_memory]=/path/to/check_nmon -F /etc/perf/nmonserver_name.nmon -k MEM -s Real Free %,Virtual free %
Then appropriate services setup in nagios that run a command something like:
$USER1$/check_nrpe -H $HOSTADDRESS$ -c check_nmon_cpu
And the like
Make sense?
raamardhani7
And the like
Make sense?
Thank you so much Jdalrymple.. You can close this thread now.. :)
