At this point, this is what I would do assuming you still have the physical server to fall back on!
Try to upgrade your Nagios installation using the guide wrote by one of our employees here.
This way we are kind of "starting over" but not really.
cloning of Nagios server
Re: cloning of Nagios server
Former Nagios Employee.
me.
me.
ok, I ran the
and there were a few more cfg files that had some config issues so I fixed those and ran it again with the following results:
Checking objects...
Checked 158 services.
Checked 72 hosts.
Checked 14 host groups.
Checked 0 service groups.
Checked 3 contacts.
Checked 3 contact groups.
Checked 37 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 72 hosts
Checked 3 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
I then rebooted, and tried to restart the nagios service again and that seemed to fix the issue. Thank you for your help with this and the fast responses!
Checking objects...
Checked 72 hosts.
Checked 3 contacts.
Checked 72 hosts
Total Warnings: 0
Total Errors: 0
Interesting!tomtom wrote:ok, I ran the
Checking objects...
Checked 72 hosts.
Checked 3 contacts.
Checked 72 hosts
Total Warnings: 0
Total Errors: 0
Am I all right to close this one? Ignore my instructions to upgrade above unless you have that upgrade itch.
me.
me.
