Cannot find Host in service escalation
JohnFLi
Re: Cannot find Host in service escalation
Post by JohnFLi »
it wouldn't let me add a forth picture.
host_name BearCam
service_description Ping
check_command check_ping!!!!!!!!
max_check_attempts 5
check_interval 5
retry_interval 1
notification_interval 60
contacts myEmail
_xiwizard genericnetdevice
register 1
Everybody is somebody else’s weirdo
JohnFLi
Post by JohnFLi »
Well, somethign was amiss for sure.
I deleted the Service Escalation, applied config....
Remade the Service Escalation (with all the same settings and hosts)....Applied Config
Went to the services of BearCam, deleted (it was happy)
Deleted the BearCam host, applied.
Nagios is now fine again.
Wierd.
But I still have
# tail -50 /var/log/mysqld.log
150731 14:15:03 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_customvariablestatus' is marked as crashed and should be repaired
150731 14:15:03 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired
150731 14:15:03 [Note] /usr/libexec/mysqld: Normal shutdown
Post by Box293 »
For the mysql error you'll need to do:
cd /usr/local/nagiosxi/scripts/
./repair_databases.sh
This may take a while to complete. Once it has, please scroll back up through the history to make sure there were not any database errors (you may see an ndo2db error when stopping the service but this is ok).
JohnFLi
Post by JohnFLi »
yup...it looks good now.
Thanks.
hsmith
Agent Smith
Post by hsmith »
JohnFLi wrote:yup...it looks good now.
Thanks.
Are we all right to mark this one as resolved?
Former Nagios Employee.
me.
JohnFLi
Post by JohnFLi »
please do
