Is this one resolved? Are you able to reproduce this?weveland wrote:Thanks that got me to the bottom of it.
I went to go check my NRDS config manager. Which was now strangely missing. It appears the problem is when you edit the configuration in the NRDS config manager and then add a token through the inbound interface, it messes up the /usr/local/nrdp/server/config.inc.php token section.
It appears to terminate the string for one token while leaving the unknown token in the opposing configuration line.
This is in the "$cfg['authorized_tokens']=array(" section
LogServer=>NagiosXI
Re: LogServer=>NagiosXI
Former Nagios Employee.
me.
me.
Sorry about that hsmith. Yes this issue is resolved. Thank you again.
