Unable to apply configuration.
mccollege
Re: Unable to apply configuration.
Post by mccollege »
Here's the output:
[root@nagios init.d]# tail -f /usr/local/nagiosxi/var/cmdsubsys.log
PROCESSED 0 COMMANDS
ESS COMMAND: CMD=17, DATA=
APPLYING NAGIOSCORE CONFIG...
CMDLINE=cd /usr/local/nagiosxi/scripts && ./reconfigure_nagios.sh
URL: http://localhost/nagiosxi/includes/components/ccm/
CMDLINE
--2015-08-28 11:53:51-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
Length: unspecified [text/html]
Saving to: `nagiosql.login'
0K .......... . 809M=0s
2015-08-28 11:53:52 (809 MB/s) - `nagiosql.login' saved [11691]
/usr/bin/wget --save-cookies nagiosql.cookies --keep-session-cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'submit=Login&hidelog=true&loginSubmitted=true&username=nagiosxi&password=sra5to' -O nagiosql.loginLOGIN SUCCESSFUL!
IMPORTING CONFIG FILES...URL: http://localhost/nagiosxi/includes/components/ccm/
Array
RESETTING PERMS
SETUID ROOT OK
CMDLINE
--2015-08-28 11:53:52-- http://localhost/nagiosxi/includes/components/ccm/
0K .......... . 786M=0s
2015-08-28 11:53:53 (786 MB/s) - `nagiosql.login' saved [11691]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosxi/includes/components/ccm/ --no-check-certificate --post-data 'cmd=apply&type=writeConfig' -O nagiosql.export.monitoring
--2015-08-28 11:53:53-- http://localhost/nagiosxi/includes/components/ccm/
Saving to: `nagiosql.export.monitoring'
0K .......... .... 1.12G=0s
2015-08-28 11:53:54 (1.12 GB/s) - `nagiosql.export.monitoring' saved [14751]
WRITE CONFIGS SUCCESSFUL!
OUTPUT:
Nagios Core 4.0.7
Last Modified: 06-03-2014
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 385 services.
Checked 144 hosts.
Checked 11 host groups.
Checked 8 service groups.
Checked 13 contacts.
Checked 7 contact groups.
Checked 125 commands.
Checked 20 time periods.
Checked 0 host escalations.
Checked 144 hosts
Checked 0 host dependencies
Checked 20 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
RET: 0
/etc/init.d/nagios: line 209: /dev/null: Permission denied
Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
OUTPUT=Running configuration check... CONFIG ERROR! Restart aborted. Check your Nagios configuration.
RETURNCODE=6
PROCESSED 1 COMMANDS
ssax
Dreams In Code
Post by ssax »
Don't apply configuration or anything in between, when an apply config fails it reverts the files back to a known working state, we want to keep the files in a bad state.
First go to Configure > Core Config Manager > Tools > Write Config Files
- Click Delete (don't worry, it's safe, they get re-written)
- Click Write
Run this command and post the full output:
Then zip up your /usr/local/nagios/etc directory and attach it here.
mccollege
Post by mccollege »
Output:
Nagios Core 4.0.7
License: GPL
Checking objects...
Checked 144 hosts.
Checked 144 hosts
Total Warnings: 0
Total Errors: 0
Post by Box293 »
Can you upload the file:
/etc/sudoers
Also, any files in /etc/sudoers.d/
mccollege
Post by mccollege »
Attached is contents of sudoers file.
No /etc/sudoers.d directory exists.
The sudoers looks fine.
What are the permissions on "/dev/null"?
ll /dev/null
mccollege
Post by mccollege »
crw-r----- 1 mysql mysql 1, 3 Aug 28 10:04 /dev/null
ssax
Dreams In Code
Post by ssax »
Try this:
chmod 666 /dev/null
chown root.root /dev/null
Then:
Apply config and send us the full output.
mccollege
Post by mccollege »
Which output do you want? What was displayed while the tail -f was going?
The configuration applied this time, and everything under the "System Ok" is green again.
I'll attach the profile if there is anything else you need to check on.
Is everything working now?
