CPU usage just stopped working
hsmith
Agent Smith
Re: CPU usage just stopped working
Post by hsmith »
How realistic is upgrading to one of the newer versions of NSClient?
Former Nagios Employee.
me.
steve.chambers
Post by steve.chambers »
as long as I don't have to upgrade Nagios or make any major changes otherwise that should not be a problem.
Can I just install over top of what is already there or is there a different recommended procedure?
hsmith
Agent Smith
Post by hsmith »
steve.chambers wrote:as long as I don't have to upgrade Nagios or make any major changes otherwise that should not be a problem.
This should not affect Nagios whatsoever. I'd back up your .ini from the Windows folder, and then uninstall via control panel (if it is an option in your version) and then install the new one.
me.
steve.chambers
OK removed old client after saving my nsc.ini (program folder rather than "Windows") installed new version (0.4.3) from here http://www.nsclient.org/download/.
Copied my nsc.ini back to the install location and restarted the service. No change
Rebooted system, still the same...
ssax
Dreams In Code
Post by ssax »
If you open up and admin powershell shell and run this command (with the exact counter your using), what does it show?
Get-Counter "\Processor Information(*)\Processor Frequency"
steve.chambers
I am not sure I understand where I plug in the counter or what name I use.
In the NagiosXI GUI it shows as CPU Usage, in the command that is sent by Nagios
check_xi_service_nsclient!PASSWORD!CPULOAD!-l 5,80,90
I assume that it is CPULOAD
If I do just a get-counter with no arguments I get this
Timestamp                 CounterSamples
9/11/2015 10:30:58 AM     \\stagedb\network interface(vmxnet3 ethernet adapter)\bytes total/sec :
                          814.670164577896
                          \\stagedb\network interface(isatap.{35aa846e-3f41-4533-a1b5-e36b7ff9adcb})\bytes total/sec :
                          0
                          \\stagedb\processor(_total)\% processor time :
                          0.10638669816645
                          \\stagedb\memory\% committed bytes in use :
                          32.806102812547
                          \\stagedb\memory\cache faults/sec :
                          0
                          \\stagedb\physicaldisk(_total)\% disk time :
                          0
                          \\stagedb\physicaldisk(_total)\current disk queue length :
                          0
Lets try and rebuild the performance counters on your Windows system.
To rebuild the Counters, open Command Prompt with Run as administrator and type:
cd c:\Windows\System32
lodctr /R
cd c:\Windows\SysWOW64
lodctr /R
WINMGMT.EXE /RESYNCPERF
You must stop and start the Performance Logs and Alerts service, open Command Prompt with Run as administrator and type:
net stop pla && net start pla
And the Windows Management Instrumentation service, open Command Prompt with Run as administrator and type:
net stop Winmgmt && net start Winmgmt
Try this and see if that fixes it.
steve.chambers
Unfortunately all those commands completed successfully but there is no change in the CPU Usage counter.
Even after submitting several forced immediate checks
Post by Box293 »
Are there any errors in the Event Viewer under Application or System?
steve.chambers
There are errors but none that seem to be related to events surrounding the CPU or error reporting, WMI or NSClient
