BPI Consider Soft State as PROBLEM
Re: BPI Consider Soft State as PROBLEM
Actually, our developers cancelled the task - here's the explanation:
Reason For Task Cancellation: This is expected behavior. If you want to get alerted only when it is hard, you can run the BPI wizard and specify a max retry level.
