NNA - Can graph no data
Re: NNA - Can graph no data
After recompiling the software, you will have to restart the Source. Click on the source in question and in the top right of the screen, there is a button you can use to restart the source.
Try that and after about 20 minutes, the tables should fill in.
botswanamtc
Post by botswanamtc »
I did as per your instructions but it did not work.
I have replaced the old router and everything is ok Now.
Thank you,
Thanks for the reply. Is it alright to close the post?
