WMI error following v5 upgrade
Re: WMI error following v5 upgrade
We had extended the script with our own "checkforoldfiles", and now that I'm typing that out i'm wondering the upgrade overwrote our version. Let me check that.
Yes, that is it. The upgrade installed a newer version of the check_wmi plugin so whatever modifications that were done will have to be re-created.
Yep makes sense, should have considered that as soon as it happened. Will have to track down the guy that extended it and have him re-do.
Thanks!
Thanks!
I am glad this is sorted out. Do you want us to keep this thread open for a while or it is safe to close it?
Go ahead and close it. Thanks!
