check_iferrors_percent
Re: check_iferrors_percent
Oops, forgot to change the -w field as well to reflect this. End of the day on a Friday, you know how that goes!
Try adding another zero after the decimal on the -w field.
Former Nagios Employee.
me.
me.
Hello.
Then I've try this command:
[root@localhost libexec]# ./check_iferrors_percent -H 10.236.4.170 -C public -w 0.00075 -c 0.001 -i 19
IFERRORS CRITICAL - Interface error rates for host 10.236.4.170 | 19_out_discards=0%;0.00075;0.001 19_in_discards=0%;0.00075;0.001 19_out_errors=0%;0.00075;0.001 19_in_errors=0%;0.00075;0.001
But result is always the same...
It seems that meausured value is not considered.
For example:
19_out_discards=0%
0% is less than warning level (0.00075). Result should be OK instead of CRITICAL...
For example:
19_out_discards=0%
It looks like the thresholds may be hardcoded into the script. Can you try to run the command without the -w and -c parameters and see what happens?
me.
me.
Hello
[root@localhost libexec]# ./check_iferrors_percent -H 10.236.4.170 -C public - i 19 IFERRORS CRITICAL - Interface error rates for host 10.236.4.170 | 19_out_discards=0%;0.0075;0.01 19_in_discards=0%;0.0075;0.01 19_out_errors=0%;0.0075;0.01 19_in_errors=0%;0.0075;0.01
Can you try to edit the hardcoded values in the plugin to meet your needs and potentially trigger a warning/critical?
me.
me.
OK.
I'll do this last test and in case of bad result I'll change strategy.
I'm not sure to follow the right method for my need...
You can close the ticket.
Thanks a lot for all Your assistance.
