check_mysql_query
garazh317
Re: check_mysql_query
Post by garazh317 »
hsmith wrote:Can you run a 'pre flight check?' /usr/lib64/nagios/bin/nagios -v /usr/lib64/nagios/etc/nagios.cfg
If that doesn't work, my paths may be slightly off. I am not used to that directory structure. How did you install Nagios? What OS is it running on?
Preflight has only 10 warnings about default contacts.
I have different directory structure. nagios -v /etc/nagios/nagios.cfg This path is right. And that grep '$USER1' /etc/nagios/private/resource.cfg.
Nagios installed on centos from yum.
ssax
Dreams In Code
Post by ssax »
Generally the only thing that would cause problems with this is special characters in the password, does your database have any special characters in it?
Did you copy and paste the check command from a document? You may want to check to make sure the dashes are really dashes and not converted to Microsoft's weird long dash. Every time I copy and paste I replace the dashes with a hand typed dash (or quote) just in case.
garazh317
Post by garazh317 »
Retyped all manually, the same problem.
hsmith
Agent Smith
Post by hsmith »
Let's enable debugging and then have you try to run the check again.
In your nagios.cfg file, change
debug_level=0 to debug_level=-1
debug_verbosity=1 to debug_verbosity=2
max_debug_file_size=1000000 to max_debug_file_size=10000000
Let us know if there are any clues in that output.
Thanks!
Former Nagios Employee.
me.
