Nagios xi installation error "pnp"
Re: Nagios xi installation error "pnp"
Thanks for rour help. I am not getting any further. Please see install log attached.
cwscribner
Assuming you're on CentOS, try
Post the output of
Now rerun the install.
yum install rrdtoolCode: Select all
ls -l /usr/local/nagios/etc/Re: Nagios xi installation error "pnp"
Thanks. I am actually running RHEL5. The output of the command is below though...
-rwxrwxr-x 1 apache nagios 744 Oct 13 12:10 cgi.cfg
drwsrwsr-x 2 apache nagios 4096 Oct 12 09:48 hosts
drwsrwsr-x 2 apache nagios 4096 Oct 12 09:48 import
-rwxrwxr-x 1 apache nagios 5764 Oct 12 09:48 nagios.cfg
-rwsrwsr-x 1 apache nagios 5764 Oct 13 12:10 nagios.cfg.xi
-rwxrwxr-x 1 apache nagios 2229 Oct 13 12:11 ndo2db.cfg
-rwxrwxr-x 1 apache nagios 4723 Oct 13 12:11 ndomod.cfg
-rwsrwsr-x 1 apache nagios 3417 Oct 13 12:11 pnp
-rwxrwxr-x 1 apache nagios 210 Oct 12 09:48 resource.cfg
-rwsrwsr-x 1 apache nagios 210 Oct 13 12:10 resource.cfg.xi
drwsrwsr-x 2 apache nagios 4096 Oct 12 09:48 services
drwsrwsr-x 2 apache nagios 4096 Oct 12 09:48 static
It seems the install is looking for a pnp folder however, it seems I have a pnp file instead. Any suggestions welcome.
Usually what its looking for the pnp folder in the install directory. I would suggest you delete the install folder. Then re-untar it and run the fullinstall script again. It moves the pnp config files to their location and then if it moved them to some location that wasn't right, it won't find them again.
Nicholas Scott
cwscribner
Could he delete the pnp file and then let the install recreate it?
Yeah, I don't see why not.
Nicholas Scott
Thank you for your help. Unfortunately, deleting the pnp file and running the install again has not worked either. The /usr/local/nagios/etc/pnp folder is not created each time the install is ran hence the messages below...
checking for rrdtool... no
checking rrdtool path ... no
configure: error: is a directory! PNP needs the Path to the rrdtool binary!
make: *** No rule to make target `all'. Stop.
make: *** No rule to make target `install'. Stop.
make: *** No rule to make target `install-config'. Stop.
make: *** No rule to make target `install-init'. Stop.
/tmp/nagiosxi/subcomponents/pnp
PNP-POST
cp: accessing `/usr/local/nagios/etc/pnp/rra.cfg': Not a directory
cp: accessing `/usr/local/nagios/etc/pnp/process_perfdata.cfg': Not a directory
cp: target `/usr/local/nagios/share/pnp/templates' is not a directory
cp: cannot create regular file `/usr/local/nagios/share/pnp/lang': No such file or directory
mkdir: cannot create directory `/usr/local/nagios/var/stats': File exists
ERROR: PNP install appears to have failed - exiting. Missing file = /usr/local/nagios/bin/npcd
ERROR: Subcomponent 'pnp' installation failed - exiting.
Subcomponents installation failed - exiting
Is there something wrong with the install script?
Any assistance is appreciated.
PNP-POST
Well, from the looks of that, it looks like rrdtool isn't install properly. Can you type
This should return a list of all packages with rrd, and then make sure there is an rrdtool in that list, then run
yum search rrdCode: Select all
yum install rrdtoolNicholas Scott
Thanks. I am starting to think that the issue I'm having is as a result of my installation being behind a proxy. I cannot seem to connect to the right repositories to install the rrdtool successfully.
Which repositories do you use? Bear in mind that I'm on RHEL5.
Again, thanks for your help.
We use the EPEL and RPMforge repos.
Nicholas Scott
