service check timeouts
quental
Re: service check timeouts
Post by quental »
the IP in server is statically.
there isn't any process nrpe in backgruond mode running. and we only have 1 service xinetd running.
I attack config file nrpe.cfg
In your nrpe.cfg, I noticed the allowed_hosts=127.0.0.1 can you add your Nagios servers IP after this comma delimited?
Example -
allowed_hosts=127.0.0.1,12.34.56.78
Replace 12.34.56.78 with your Nagios servers IP.
Additionally, can you run the following command and post the output -
cat /etc/xinetd.d/nrpe|grep only_from
quental
Post by quental »
We added the Nagios server IP in our nrpe.cfg
This is the result of the command:
only_from = 127.0.0.1 192.168.247.128
Did you restart the NRPE service after? Did it start working?
If it's running under xinet.d -
service xinet.d restart
quental
Post by quental »
Yes, we restart the NRPE service after the change. It´s running under xinetd.
The problem happened again after the change.
Some days the checks running well, but another days fails.
Can you run the following on the system that is having problems and post back the results?
ulimit -a
su nagios
ulimit -a
quental
Post by quental »
address space limit (kbytes) (-M) unlimited
core file size (blocks) (-c) 0
cpu time (seconds) (-t) unlimited
data size (kbytes) (-d) unlimited
file size (blocks) (-f) unlimited
locks (-L) unlimited
locked address space (kbytes) (-l) 32
nice (-e) 0
nofile (-n) 4096
nproc (-u) 773390
pipe buffer size (bytes) (-p) 4096
resident set size (kbytes) (-m) unlimited
rtprio (-r) 0
socket buffer size (bytes) (-b) 4096
stack size (kbytes) (-s) 10240
threads (-T) not supported
process size (kbytes) (-v) unlimited
Can you post the following files so we can review them?
/etc/security/limits.conf
And the contents of this folder
/etc/security/limits.d
Next time you get this error, can you check the log files in /var/log to see if there are any other errors that could be helpful?
quental
Post by quental »
ets@prometeo:/etc/security # cat limits.conf
# /etc/security/limits.conf
#Each line describes a limit for a user in the form:
#<domain>        <type>  <item>  <value>
#Where:
#<domain> can be:
#        - an user name
#        - a group name, with @group syntax
#        - the wildcard *, for default entry
#        - the wildcard %, can be also used with %group syntax,
#                 for maxlogin limit
#<type> can have the two values:
#        - "soft" for enforcing the soft limits
#        - "hard" for enforcing hard limits
#<item> can be one of the following:
#        - core - limits the core file size (KB)
#        - data - max data size (KB)
#        - fsize - maximum filesize (KB)
#        - memlock - max locked-in-memory address space (KB)
#        - nofile - max number of open files
#        - rss - max resident set size (KB)
#        - stack - max stack size (KB)
#        - cpu - max CPU time (MIN)
#        - nproc - max number of processes
#        - as - address space limit
#        - maxlogins - max number of logins for this user
#        - maxsyslogins - max number of logins on the system
#        - priority - the priority to run user process with
#        - locks - max number of file locks the user can hold
#        - sigpending - max number of pending signals
#        - msgqueue - max memory used by POSIX message queues (bytes)
#        - nice - max nice priority allowed to raise to
#        - rtprio - max realtime priority
#*               soft    core            0
#*               hard    rss             10000
#@student        hard    nproc           20
#@faculty        soft    nproc           20
#@faculty        hard    nproc           50
#ftp             hard    nproc           0
#@student        -       maxlogins       4
*       soft    nofile  4096
*       hard    nofile  4096
# End of file
ets@prometeo:/etc/security/limits.d # ls -l
total 0
Ok, next time i'll check the log files in /var/log
So far everything looks good. Hard to find something that fails intermittent.
The only thing else I can thing of is that the connections to the NRPE agent are not getting dropped and that could cause it to fail.
Can you run the following and post back here.
netstat -an
