Nagios check_cpu_stats not triggering alerts
ajaybguthi1
Re: Nagios check_cpu_stats not triggering alerts
Yep its working fine and also i did compare the other services they all have the same settings.
jdalrymple
- Skynet Drone
Simulate the failure that you expect to cause an alert, then post the results of:
grep "Author_CPU_Stats" /usr/local/nagios/var/nagios.log | grep '\(SOFT\|HARD\)'
