contacts.cfg is not working properly
sinkak
Re: contacts.cfg is not working properly
Post by sinkak »
yes in same file contacts_nagios2.cfg
hsmith
Agent Smith
Post by hsmith »
Is the file properly defined in nagios.cfg?
grep contacts_nagios2.cfg /usr/local/nagios/etc/nagios.cfg
Former Nagios Employee.
me.
sinkak
Post by sinkak »
i didnt specify each file in nagios.cfg.
i put all the servers config in a folder and specified that folder.
For example
# Debian uses by default a configuration directory where nagios3-common,
# other packages and the local admin can dump or link configuration
# files into.
cfg_dir=/usr/local/nagios/etc/conf.d
conf.d folder has all the server config files in separate folders and also contacts folder.
ubuntu@nagios-2015:/usr/local/nagios/etc/conf.d$ ls
admin-resourses dc-servers generic-host_nagios2.cfg ips rds service_groups.cfg timeperiods_nagios2.cfg webservers-stage
cacheservers elb generic-service_nagios2.cfg localhost_nagios2.cfg riak services.cfg weblinux-servers
contacts extinfo_nagios2.cfg hostgroups_nagios2.cfg pnp4nagios.cfg schedulers services_nagios2.cfg webservers
hsmith
Agent Smith
Post by hsmith »
All right, just wanted to eliminate that one from the pool. What version of core are you using? I believe in older versions you had to specify
        host_notifications_enabled	     1
	service_notifications_enabled	1
in the contact definition.
https://assets.nagios.com/downloads/nag ... ml#contact
me.
sinkak
Post by sinkak »
Nagios® Core™ 4.0.8
hsmith
Agent Smith
Post by hsmith »
Could you post one of the service definitions that is failing to send out an alert?
me.
sinkak
Post by sinkak »
Free disks space, Check_HTTP critical checks.
They are showing up as critical in [email protected].
But not in [email protected]
hsmith
Agent Smith
Post by hsmith »
Can you post the actual service definition from the configuration file?
Such as:
	host_name		linux-server
	service_description	check-disk-sda1
	check_command		check-disk!/dev/sda1
	max_check_attempts	5
	check_interval	5
	retry_interval	3
	check_period		24x7
	notification_interval	30
	notification_period	24x7
	notification_options	w,c,r
	contact_groups		linux-admins
me.
sinkak
Post by sinkak »
        use                             generic-service,srv-pnp
        hostgroup_name                  weblinux-servers
        service_description             Free disks space
        contact_groups                  admins
        check_command                   check_nrpe_args!check_all_disks!20%!10%
        _graphiteprefix                 ua-east-1a.weblinux
        _graphitepostfix                disk
hsmith
Agent Smith
Post by hsmith »
What is the output of a grep -Pzo "(?s)^define\s*?(contact|contactgroup)\s*.*?}" /usr/local/nagios/var/objects.cache command?
me.
