Nagios Log Server Install doesn't open UDP 5544 in firewall
mark.payne
Re: Nagios Log Server Install doesn't open UDP 5544 in firew
Post by mark.payne »
jolson wrote:@mark.payne,
127.0.0.1 is the default address because Nagios Log Server isn't sure which node you'd like to pull the actual address from. You can manually specify the address here:
That worked. I had it blank.
Interesting that sometimes it was using the IP of eth0 and sometimes it was 127.0.0.1. Must be something there causing it.
Should never use 127.0.0.1 for those URLs I would imagine.
jolson
Attack Rabbit
Post by jolson »
This is something that is known and has been brought up before. As always, thanks for the feedback Mark. :D
Twits Blog
