How to Monitor locally attached storage disks
Re: How to Monitor locally attached storage disks
Check your services and look for NSClient++ to see if it's running or not.
Additionally, is a firewall running on the Windows server?
bsivavani
Post by bsivavani »
NSClient++ service is running.
Is a firewall running on the Windows server? Run the following commands on the Nagios XI server from the command line and show the output:
ip addr
nmap <client ip> -p 5666
bsivavani
Post by bsivavani »
[root@irv-monprd001 libexec]# nmap 10.105.0.176 -p 5666
nmap: error while loading shared libraries: libsvn_client-1.so.0: cannot open shared object file: No such file or directory
I have checked with network team and found there is no firewall between Nagios and client.
Is there one running on the exchange machine?
Can you run the following on your windows machine and post the output -
netstat -na | find ":5666"
bsivavani
Post by bsivavani »
C:\Program Files\NSClient++>netstat -na | find ":5666"
TCP 10.105.0.176:443 10.105.0.221:56665 ESTABLISHED
TCP 10.105.0.176:56565 10.11.3.146:56668 ESTABLISHED
TCP 10.105.0.176:56817 10.11.3.146:56669 ESTABLISHED
TCP 10.105.0.176:56817 10.52.142.49:56664 ESTABLISHED
It does not look like your NSClient is running. Can you navigate to your services and start the NSClient++ service?
bsivavani
Post by bsivavani »
NSClient service is running. It is listening on port 12489
C:\Program Files\NSClient++>netstat -na | find ":12489"
TCP 0.0.0.0:12489 0.0.0.0:0 LISTENING
TCP 10.105.0.176:12489 10.105.9.180:45568 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45699 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45704 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45708 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45727 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45736 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45810 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45838 TIME_WAIT
TCP 10.105.0.176:12489 10.105.9.180:45931 TIME_WAIT
TCP [::]:12489 [::]:0 LISTENING
I would like to know why it is not listening on 5666 and what are the steps I have to take for make it is listening.
hsmith
Agent Smith
Post by hsmith »
Can you try this nsclient.ini instead of yours?
# If you want to fill this file with all avalible options run the following command:
#   nscp settings --generate --add-defaults --load-all
#   nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 10.105.90.180
[/modules]
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; NSClientServer - A server that listens for incoming check_nt connection and processes incoming requests.
NSClientServer = 1
; CheckExternalScripts - Execute external scripts
CheckExternalScripts = 1
; CheckHelpers - Various helper function to extend other checks.
CheckHelpers = 1
; CheckEventLog - Check for errors and warnings in the event log.
CheckEventLog = 1
NRPEServer = 1
; CheckNSCP - Use this module to check the healt and status of NSClient++ it self
CheckNSCP = 1
; CheckDisk - CheckDisk can check various file and disk related things.
CheckDisk = 1
; A list of templates for wrapped scripts.
[/settings/external scripts/wrappings]
; WRAPPING - An external script wrapping
vbs = cscript.exe //T:30 //NoLogo scripts\\lib\\wrapper.vbs %SCRIPT% %ARGS%
bat = scripts\\%SCRIPT% %ARGS%
An alias is an internal command that has been predefined to provide a single command without arguments. Be careful so you don't create loops (ie check_loop = check_a, check_a=check_loop)
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
[/settings/external scripts/alias]
; ALIAS - Query alias
alias_volumes = check_drivesize
alias_up = check_uptime
alias_sched_all = check_tasksched show-all "syntax=${title}: ${exit_code}" "crit=exit_code ne 0"
alias_process_hung = check_process "filter=is_hung" "crit=count>0"
alias_process = check_process "process=$ARG1$" "crit=state != 'started'"
alias_file_size = check_files "path=$ARG1$" "crit=size > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${size}" max-dir-depth=10
alias_event_log = check_eventlog
alias_service_ex = check_service "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
alias_cpu_ex = check_cpu "warn=load > $ARG1$" "crit=load > $ARG2$" time=5m time=1m time=30s
alias_file_age = check_files "path=$ARG1$" "crit=written > $ARG2$" "top-syntax=${list}" "detail-syntax=${filename] ${written}" max-dir-depth=10
alias_process_stopped = check_process "process=$ARG1$" "crit=state != 'stopped'"
alias_service = check_service
; default - Alias for default. To configure this item add a section called: /settings/external scripts/alias/default
default =
alias_cpu = check_cpu
alias_mem = check_memory
alias_volumes_loose = check_drivesize
alias_disk = check_drivesize
alias_process_count = check_process "process=$ARG1$" "warn=count > $ARG2$" "crit=count > $ARG3$"
alias_disk_loose = check_drivesize
alias_sched_task = check_tasksched show-all "filter=title eq '$ARG1$'" "detail-syntax=${title} (${exit_code})" "crit=exit_code ne 0"
alias_sched_long = check_tasksched "filter=status = 'running'" "detail-syntax=${title} (${most_recent_run_time})" "crit=most_recent_run_time < -$ARG1$"
[/settings/NRPE/server]
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket.  default-workarounds	Various workarounds for what I understand to be broken ssl implementations no-sslv2	Do not use the SSLv2 protocol. no-sslv3	Do not use the SSLv3 protocol. no-tlsv1	Do not use the TLSv1 protocol. single-dh-use	Always create a new key when using temporary/ephemeral DH parameters. This option must be used to prevent small subgroup attacks, when the DH parameters were not generated using "strong" primes (e.g. when using DSA-parameters).
ssl options =
allow arguments = true
; VERIFY MODE - Comma separated list of verification flags to set on the SSL socket.  none	The server will not send a client certificate request to the client, so the client will not send a certificate. peer	The server sends a client certificate request to the client and the certificate returned (if any) is checked. fail-if-no-cert	if the client did not return a certificate, the TLS/SSL handshake is immediately terminated. This flag must be used together with peer. peer-cert	Alias for peer and fail-if-no-cert. workarounds	Various bug workarounds. single	Always create a new key when using tmp_dh parameters. client-once	Only request a client certificate on the initial TLS/SSL handshake. This flag must be used together with verify-peer
verify mode = none
; ALLOW INSECURE CHIPHERS and ENCRYPTION - Only enable this if you are using legacy check_nrpe client.
insecure = true
allow nasty characters=true
; A list of scripts available to run from the CheckExternalScripts module. Syntax is: <command>=<script> <arguments>
; default - Alias for default. To configure this item add a section called: /settings/external scripts/scripts/default
default =
; A set of filters to use in real-time mode
[/settings/eventlog/real-time/filters]
; default - Filter for default. To configure this item add a section called: /settings/eventlog/real-time/filters/default
default =
Reload the NSClient service after changing your file:
net stop nscp
net start nscp
Former Nagios Employee.
me.
bsivavani
Post by bsivavani »
I am able to connect client server with port 5666 from Nagios. Thanks for your help.
I am going to monitor mount volume and will reach you if I face any issues.
