Process Count not working after NSclient upgrade
Re: Process Count not working after NSclient upgrade
Post by Box293 »
ranjitw wrote:Hi,
I have not checked the process count . I am getting new errors now for all the checks :
NSClient - ERROR: Invalid return from command: check_drivesize
Please suggest how to resolve this issue.
I suspect your nsclient.ini file was overwritten or lost.
This guide will help you re-create it:
http://sites.box293.com/nagios/guides/n ... t-ini-file
ranjitw
Post by ranjitw »
Any idea on when the next official release would be ?
Regards,
Ranjit W
As NSClient is a separate product, we do not have a clue when the next release will be.
Did you try the instructions posted by Box293 above?
