Monitoring new routers
jdalrymple
Skynet Drone
Re: Monitoring new routers
Post by jdalrymple »
Is there a reason you're setting your timeout to 1?
When you tried the walk did you set the timeout to 1? If not this is almost certainly an SNMP configuration problem on the device itself.
CUTM
Post by CUTM »
No specific reason for using 1 as the timeout... I re-ran the snmpwalk with a longer timeout and it still failed to respond. I'm also starting to think the router config needs an update.
hsmith
Agent Smith
Post by hsmith »
I would definitely take a look at the router config. Let us know what you come up with.
Former Nagios Employee.
me.
