Log server installation issue - no clues
jolson
Attack Rabbit
Re: Log server installation issue - no clues
Post by jolson »
Reversed (or previously applied) patch detected! Assume -R? [n]
Apply anyway? [n]
Try using 'y' at the above points instead of 'n'.
Twits Blog
gjcoevert
Post by gjcoevert »
As far as I know, there is no option to use 'y' in this automated procedure, is there?
One of the scripts ( nagioslogserver/curator-expandwildcards.patch) which is kicked off during the installation of the Nagios Logserver, is executing the following code:
--- curator.py~ 2015-07-20 17:21:21.300099384 -0400
+++ curator.py  2015-07-20 17:21:52.605118057 -0400
@@ -220,7 +220,7 @@
 def get_indices(client, prefix='logstash-', exclude_pattern=None):
     """Return a sorted list of indices matching prefix"""
-    _indices = sorted(client.indices.get_settings(index=prefix+'*', params={'expand_wildcards': 'closed'}).keys())
+    _indices = sorted(client.indices.get_settings(index=prefix+'*', params={'expand_wildcards': 'open,closed'}).keys())
     if exclude_pattern:
         pattern = re.compile(exclude_pattern)
         return list(filter(lambda x: not pattern.search(x), _indices))
This is the script which is causing the installation to fail. You could either adjust the file curator.py yourself to the original value, before patching.
Or you could deinstall the python package by running
pip uninstall elasticsearch-curator
. This should be done from the directory /usr/lib/python2.7/site-packages (in case of RHEL 7). when choosing this option, you should remove and unpacke the nagioslogserver-latest.tar.gz once again. And run
./fullinstall
This worked for me...
jolson
Attack Rabbit
Post by jolson »
@gjcoevert, that is the correct procedure - thank you.
@sangeetha, please let us know if this works for you.
Twits Blog
sangeetha
Post by sangeetha »
I had gone with the VM rebuilt and my problem was solved.
thank you.
jolson
Attack Rabbit
Post by jolson »
Excellent, may I close this thread?
Twits Blog
