Updating Units in RRD graphs
Re: Updating Units in RRD graphs
I believe it's just the plugin/service/command configuration that will be updated and actually matters, but I am not sure as to the intended behavior of the MRTG files. I know at one point there was talk of improving that process, but I cannot find anything in the changelogs. I've asked the devs for clarification and will update when I know more.
ssax
Dreams In Code
Post by ssax »
From what I'm seeing, it doesn't look like you need to update the MRTG files, only the UOM in the services (that's assuming you're setting up new perfdata RRDs in /usr/local/nagios/share/pefdata/switchname).
I ran the wizard choosing Gbps AND Mbps and the MRTG config files had no differences, they only thing that changed was the G or M on the check command (in the Nagios CCM).
