check_jenkins_job_extended plugin - JSON.pm query
neworderfac33
Re: check_jenkins_job_extended plugin - JSON.pm query
Post by neworderfac33 »
Good morning,
I trued what you suggested, but it returns
 Failed retrieving status for last build via API (API status line: )
whether I use http or https.
I think I might just call time on this one :-(
Thanks for your help.
Pete
I don't want to let you give up - as it's not an in house plugin, we can't fully support it. I would recommend posting on the Github to see if you can reach a resolution through that route with the original creator. It looks like a few people have created forks as well, which may provide a solution. Below are a couple links -
- https://github.com/jrottenberg/check_jenkins
- https://github.com/Ericbla/check_jenkins
