This bug was from 2015, I've also reported an issued which has been acknowledged in this 2016 thread: https://support.nagios.com/forum/viewto ... 16&t=37976matt.lilek wrote:Hey Guys,
Long time lurker here. I do post just not for a while. I have 2 things that worked for this issue. 1. Change Proxy 2. Disable Proxy. I have 3 systems and 2 had issues with this even after 5.2.7 One i changed the proxy to match the one that was working fine and that worked. The other instance doing the same didnt work well because it was already using that proxy so i just disabled it. Dont know if something is getting stuck or a switch is not occurring or what but i thought i would just chime in. Let me know if this helps.
BUG: Installation failed, check internet connectivity...
Re: BUG: Installation failed, check internet connectivity...
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
I thought this bug was already fixed but I could be wrong. I posted a new internal bug report about this issue (TASK ID 8297), which has been already fixed by our developers. It was just a "bogus" message. That problem was that that script was actually trying to remove a temp directory twice, which was causing the error, even though installation was working properly.
