This support forum board is for questions relating to
Nagios Fusion .
raamardhani7
Posts: 459 Joined: Tue Jun 02, 2015 12:36 am
Post
by raamardhani7 » Wed Nov 25, 2015 1:12 pm
jolson wrote: I'm interested in the following:
cat /etc/sudoers
ls /etc/cron.d/
cat /etc/cron.d/nagiosxi
tail -n200 /var/log/cron
tail -n200 /var/log/secure
egrep "apach|nagios" /etc/passwd
egrep "apach|nagios" /etc/group
Thank you!
Jesse
Hi Jesse
I am really sorry for troubling you people, my password is expired and I have set it to non expiry. Things started working fine, but below is the error now..
tail -20 /usr/local/nagiosfusion/var/poller.log
Saving Tac Data to DB: LUSSVPNAGIOSXI00
Saving Tac Data to DB: LBSCHPNAGIOSXI00
Saving Tac Data to DB: LCNHKPNAGIOSXI00
CMD: /usr/local/nagiosfusion/html/includes/components/nocscreen/nocfetch.php host 32b9gk >> /usr/local/nagiosfusion/var/components/noc.log
CMD /usr/local/nagiosfusion/html/includes/components/nocscreen/nocfetch.php service 32b9gk >> /usr/local/nagiosfusion/var/components/noc.log
CMD: /usr/local/nagiosfusion/html/includes/components/nocscreen/nocfetch.php host 9q240u >> /usr/local/nagiosfusion/var/components/noc.log
CMD /usr/local/nagiosfusion/html/includes/components/nocscreen/nocfetch.php service 9q240u >> /usr/local/nagiosfusion/var/components/noc.log
CMD: /usr/local/nagiosfusion/html/includes/components/nocscreen/nocfetch.php host rkjriu >> /usr/local/nagiosfusion/var/components/noc.log
CMD /usr/local/nagiosfusion/html/includes/components/nocscreen/nocfetch.php service rkjriu >> /usr/local/nagiosfusion/var/components/noc.log
Polling Recent Alerts...
NAGIOSXI ALERT FETCH LUSSVPNAGIOSXI00
PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 98462638 bytes) in /usr/local/nagiosfusion/html/includes/utilsx.inc.php on line 114
Posts: 13589 Joined: Mon May 23, 2011 12:15 pm
Post
by lmiltchev » Wed Nov 25, 2015 2:05 pm
Run the following command from the CLI on the Fusion box and show us the output:
You may need to bump up the value and restart apache:
Hope this helps.
Be sure to check out our
Knowledgebase for helpful articles and solutions!
raamardhani7
Post
by raamardhani7 » Wed Nov 25, 2015 2:37 pm
lmiltchev wrote: Run the following command from the CLI on the Fusion box and show us the output:
Hope this helps.
Have changed the value to
From
grep memory_limit /etc/php.ini
memory_limit = 128M
to
memory_limit = 512M
Recycled crond and httpd. 512M is this a good move? or do I need to reduce???
Post
by lmiltchev » Wed Nov 25, 2015 2:53 pm
512M should be good, depending on your resources. What is the output of the following command?
Is the issue resolved now?
raamardhani7
Post
by raamardhani7 » Wed Nov 25, 2015 3:34 pm
lmiltchev wrote: 512M should be good, depending on your resources. What is the output of the following command?
Hi...
Issue is sorted..
free -b
total used free shared buffers cached
Mem: 8255045632 1911361536 6343684096 30121984 121647104 400056320
-/+ buffers/cache: 1389658112 6865387520
Swap: 4227854336 0 4227854336
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Wed Nov 25, 2015 11:03 pm
It is OK to lock this thread?
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
raamardhani7
Post
by raamardhani7 » Thu Nov 26, 2015 11:49 am
Box293 wrote: It is OK to lock this thread?
Please close this thread, thank for the update..
