Consolidated Services using Wizards
chicjo01
Re: Consolidated Services using Wizards
Post by chicjo01 »
rkennedy wrote:The tracking system is internal only. I looked at 7193, and 7194 - at this point they are still in the developers to-do pool.
Feel free to post back when you'd like to check for an update once again.
Can you provide an update and a rough timeframe of when these tasks will start to get worked?
hsmith
Agent Smith
Post by hsmith »
It looks like they are still waiting to be approved and assigned to someone. I can't provide a timeframe, as I do not have one available, the best I can provide is the current status.
Former Nagios Employee.
me.
chicjo01
Post by chicjo01 »
Can you provide an update on 7193 and 7194 in your tracking system?
They are still pending approval at this point.
chicjo01
Post by chicjo01 »
hsmith
Agent Smith
Post by hsmith »
They have not yet been approved by the developer.
me.
gormank
Post by gormank »
While not as elegant as using the API, I'd probably create hostgroup, and host boilerplate files, search and replace strings such as hostgroup name, hostname, and address, drop the files into the import dir and run the reconfig script. This would add the host, the host to the hostgroup, and apply monitoring to services that have the hostgroup assigned to them.
The hostgroup base file needn't have all the hosts, just the one to add. Import doesn't remove, it only adds to or modifies what's already in the config.
Combine this with templates and you can separate monitoring from host and service definitions entirely.
chicjo01
Post by chicjo01 »
gormank wrote:While not as elegant as using the API, I'd probably create hostgroup, and host boilerplate files, search and replace strings such as hostgroup name, hostname, and address, drop the files into the import dir and run the reconfig script. This would add the host, the host to the hostgroup, and apply monitoring to services that have the hostgroup assigned to them.
Thank you for the suggestion. That may be the route taken, depending on how long it takes for the API to be approved and rolled out. My co-worker who is working on that section wants to use the API and avoid file manipulation.
hsmith
Agent Smith
Post by hsmith »
Thanks for the help, @gormank.
@chicjo01, I apologize this has not been implemented yet, the developers have a very high load at all times, and not all feature requests make it within a month or two of them being requested.
me.
norm_PH
Post by norm_PH »
