The server has 32gig of physical memory. What should we increase heap size too?
The reason they are open back to July is they want to be able to search 6 months back. So far most queries are only looking back 3 months. What would best practices be? Close them after 3 months to improve performance? Then does that mean that we would have to go in and open up each index they want to search? That would be opening 90+ indices. Would adding another node improve performance?
The other issue I have was when I set the date to July, it only searched back to 10/30 and it only displayed the data from the current date and time.
Appreciate your patience.
Need some help on accessing log data
Re: Need some help on accessing log data
If your instance has 32GB of usable memory, the HEAP_SIZE should be _at least_ 16GB. To enable this to be handled automatically, you can set up your elasticsearch config file like so:
vi /etc/sysconfig/elasticsearch
Change:
To:
Restart Elasticsearch:
After the restart, Elasticsearch should be able to cache 12x more data than previously. Let me know if this helps with performance.
As far as LS_HEAP_SIZE in the /etc/sysconfig/logstash file, we recommend 1024m as a maximum for now.
Otherwise, I'm not sure exactly what is wrong. The fastest way to get this figured out is likely through a remote session - feel free to email [email protected] and link back to this thread - I'd be happy to take your ticket and present you with a remote session. Thanks!
Change:
ES_HEAP_SIZE=1024mCode: Select all
ES_HEAP_SIZE=$(expr $(free -m|awk '/^Mem:/{print $2}') / 2 )mCode: Select all
service elasticsearch restartAs far as LS_HEAP_SIZE in the /etc/sysconfig/logstash file, we recommend 1024m as a maximum for now.
It will roughly double speed of data querying (you can read from both instances at the same time).Would adding another node improve performance?
