CRITICAL -PLUGIN TIMED OUT WHILE EXECUTING THE SYSTEM CALL
SJ04
Re: CRITICAL -PLUGIN TIMED OUT WHILE EXECUTING THE SYSTEM CA
Post by SJ04 »
I am Totally New with Switch and Nagios. i dont have the OID , if you can tell me where can i get it from MIB or somewhere ?
this will be really Helpful.
thanks alot
SJ04
Post by SJ04 »
I don't have the OID , how can i get it or From where i can have this OID for Switches? i am dealing with HP switches.
thanks alot
SJ
hsmith
Agent Smith
Post by hsmith »
I assume you never installed the MIB for this switch? Do you happen to know if you have the MIB? If not, I can perhaps try to help you find it if you have the model number. Sometimes these are only provided to the actual customers though. Perhaps take a look at these third party blog post I found: http://blog.davidvassallo.me/2010/03/02 ... to-nagios/ http://sites.box293.com/nagios/guides/other/snmp <---- this one is wrote by one of our employees, but is not 'official'
Former Nagios Employee.
me.
SJ04
Post by SJ04 »
hsmith wrote:I assume you never installed the MIB for this switch? Do you happen to know if you have the MIB? If not, I can perhaps try to help you find it if you have the model number. Sometimes these are only provided to the actual customers though. Perhaps take a look at these third party blog post I found: http://blog.davidvassallo.me/2010/03/02 ... to-nagios/ http://sites.box293.com/nagios/guides/other/snmp <---- this one is wrote by one of our employees, but is not 'official'
Hi Hsmith,
this is really Helpful of you.you are right I never installed any MIB for any switch. i have few Different switches here and i just got in this Company .
so i have switched which are mainly from HP and here is the Modle Number : HP ProCurve switch j8768A
if its nessaray i can also contact to the Hp or seller of the Switch.
thanks alot for your Help.
SJ04
Post by SJ04 »
HI Hsmith.
i found this MIB from HP sites.
I will give a try with it. pasted the Link.
http://h17007.www1.hp.com/us/en/support ... -sw-p.aspx
thanks
SJ
Let us know how this works out for you!
SJ04
Post by SJ04 »
HI Guys,
I have Found the Mib files In this Link but i couldnt Find the Specific Mib file and OId values for My Hp Switch to Check the Uptime.
https://h10145.www1.hpe.com/downloads/S ... ber=J8164A
can some one Help me , how can i load the MIB files to nagios and get the Uptime value for the Switch.
thanks
hsmith
Agent Smith
Post by hsmith »
Can you output the SNMPWalk command vs the switch into a text file, and PM me the file to take a look at? Seeing the MIB doesn't help me a ton.
me.
hsmith
Agent Smith
Post by hsmith »
I have received the contents of the command. I will look at them and report back.
me.
SJ04
Post by SJ04 »
hi Guys,
i have installed the MIB to SNMP Folder and I am getting this error when i run manual Check.
./check_snmp -H 10.49.0.10 -c media -o .1.3.6.1.2.1.1.3 -m all
External command error: Bad month in timestamp (201220220800Z): At line 13 in /usr/share/snmp/mibs/hpicfTC.mib
Bad month in timestamp (201220220800Z): At line 21 in /usr/share/snmp/mibs/hpicfTC.mib
Undefined OBJECT-GROUP (dot11PhyFHSSComplianceGroup): At line 2353 in /usr/share/snmp/mibs/ieee80211.mib
Undefined OBJECT-GROUP (dot11PhyIRComplianceGroup): At line 2346 in /usr/share/snmp/mibs/ieee80211.mib
Bad month in timestamp (201215110000Z): At line 45 in /usr/share/snmp/mibs/hpicfDot1x.mib
Undefined OBJECT-GROUP (hpicfUsrAuthNotificationGroup1): At line 2337 in /usr/share/snmp/mibs/hpicfUsrAuth.mib
Undefined OBJECT-GROUP (hpicfUsrAuthNotificationGroup1): At line 2315 in /usr/share/snmp/mibs/hpicfUsrAuth.mib
