monitor clustered shared volumes in 2012 R2 using Nagios
Re: monitor clustered shared volumes in 2012 R2 using Nagios
I looked around and couldn't find a plugin for checking the latency of a CSV. I'm sure it's possible though, you can always write your own power shell script, and integrate it with Nagios!
Yes, you should be able to do that. Just modify the variables for $warninglevel as needed.
$warninglevel = 15 # The percent to send warning at
jyoti22
Post by jyoti22 »
for latency monitoring I found "check_ms_win_disk_load.ps1" script
I kept it in scripts folder and made below changes in nsclient.ini
check_csv = check_csv.ps1
check_ms_win_disk_load = cmd /c echo scripts/check_ms_win_disk_load.ps1 $ARG1$; exit($LastExitCode) | powershell.exe -command –
now when I run the command on management server I get below error
[root@auscrpmonprd00 libexec]# ./check_nrpe -H 10.163.224.67 -p 5666 -t 120 -c check_ms_win_disk_load -a '-H localhost'
Failed to execute check_ms_win_disk_load: 87: The parameter is incorrect.
but when I check the script locally then it runs fine
PS C:\Program Files\NSClient++\scripts> .\check_ms_win_disk_load.ps1
OK: Drive C: Avg of 2 samples: {Rate (Read: 0.00000MB/s)(Write: 0.09570MB/s)} {Avg Nr of (Reads: 0.00000r/s)(Writes: 9
.99948w/s)} {Latency (Read: 0.00000ms)(Write: 0.17750ms)} {Queue Length (Read: 0.00000ql)(Write: 0.00355ql)} | 'Read_L
atency'=0.00000ms 'Write_Latency'=0.17750ms 'Read_Queue'=0.00000ql 'Write_Queue'=0.00355ql 'Number_of_Reads'=0.00000r/
s 'Number_of_Writes'=9.99948w/s 'Read_Rate'=0.00000MB/s 'Write_Rate'=0.09570MB/s
What can be the issue?
Maybe @WillemDH has a comment, but I believe the syntax is wrong.
Can you try with the following?
./check_nrpe -H 10.163.224.67 -p 5666 -t 120 -c check_ms_win_disk_load -a '-dl C -ms 5 -rqw 20 -rqc 50'
On the site for the plugin, https://outsideit.net/check-ms-win-disk-load/ - it also mentions needing to create a custom command for check_ms_win_disk_load to use in Nagios rather than the check_nrpe command. Did you create one?
jyoti22
Post by jyoti22 »
I will try to created new command for check_ms_win_disk_load.
Meanwhile can anyone help me on script for latency monitoring for CSV's. I am not a Unix or scripting person so it would be great if some one has script for it. Thanks.
I thought that the check_ms_win_disk_load was for monitoring your CSV? What are you looking to monitor now?
jyoti22
Post by jyoti22 »
I would like to monitor latency of CSV
jyoti22 wrote:for latency monitoring I found "check_ms_win_disk_load.ps1" script
I'm confused - Isn't that what the script you found does already?
jyoti22
Post by jyoti22 »
this script does monitor latency of standalone disk. I would like to monitor latency of clustered shared volumes.
For clarification, which script are you referring to?
The script listed here @ https://support.nagios.com/forum/viewto ... 088#p51332 should monitor all CSV's.
As for writing your own, do you know how to check the latency through powershell on a CSV?
jyoti22
Post by jyoti22 »
i don't see any particular command to check latency for those shared volumes. "C:\ClusterStorage\Volume1" is the path of these volume.
Can it be possible to monitor IO latency of it same like C: drive using check_ms_win_disk_load.ps1?
