the wizard is 1.2.2,
It links to the same 2 references you posted.
The third paragraph in the PDF recommends using the NCPA client for greater functionality over the NSClient++ so I did just that.
but then the check fails.... nothing tells you that the wizard references NSClient++ only.
Micorosft exchange 2010 critical errors
Re: Micorosft exchange 2010 critical errors
Yea, that is a bit unclear. I'll see about getting that wording fixed, or having the wizard specify that it uses NSClient.
